Re: Noise Blast - The Return
This is probably plug in related. I ran into this as well with a plug in, and when I notified the plug in manufacturer, they fixed it right away.
Can you narrow down the plug ins in your session?
Sign up for all things....AWESOME! Kris May the music move you |
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! |
Could Avid not be held responsible for any damage?
It might be an out of date plug-in - as far as I know all my plugs are up to date, but it's something I'll have a look at. I'll also check out the auto-mute plug, thanks for the link.
It's just not something that any DAW software should allow to happen though really is it. I had a client in with me at the time and he looked as shellshocked as I felt. |
Hard to believe a plugin is actually the root cause. I've never had this happen in any of my other software that uses plugins. The software should have some method of preventing this. The audio meter clearly shows +736dB peak. Channels should not even be able to output audio at this level. There should be some mechanism in place or something that if audio surpasses a certain dB level on a channel, like maybe +20dB the audio should be disabled. Even if it is a plugin causing this, Pro Tools should not allow this. This could quickly ruin a recording session if this were to happen in a performers headphones.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
#16
.... from a "Duty of Care" perspective, or from any other angle you can think of, ruining a recording session is an infinitesimal cost, compared with ruining a performer’s hearing.
#17
Update please... has a cause been found?
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
#18
Hi all,
This isn't intended to be an alternative to tracking down & fixing the bug (which is clearly needed), but I've submitted an Ideascale entry for an app-wide failsafe against dangerous output volumes: http://protools.ideascale.com/a/dtd/...ts/266672-3779 The idea being that we can greatly reduce the bug's impact this way (and make the thought of future resurgences less frightening) whilst Avid fix the individual causes. Would appreciate if anyone in support of this idea can give it a vote, just in case Avid happen to pay the site any attention. More context available here: http://duc.avid.com/showthread.php?t=390024&page=2 |
#19
Voted on it FWIW. Yes the software should just not allow a > x jump in level in any output level in less than y amount of time. The max rate of change for a 20kHz signal is well known. Pretty much anything above that is a warning and more than a few samples in a row that exceed that rate of change (or a single sample at let's say 2X that rate of change) should result in an error stoppage or mute event. Simple math really. Using this method one could monitor at - 20dBFS and be well protected long before the output reaches 0dBFS. Protecting me at -1dBFS is not really protection. -1dBFS of pure noise is just as damaging. Any chance the company will implement anything like this though?
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html Last edited by propower; 03-29-2017 at 10:52 AM. |
#20
Vastly superior to anything I could have suggested, but that's why I kept the idea high-level. Thanks for the support! Ideascale's very from a guarantee of inclusion, but it's worth a shot.
Pro Tools 2018.1 (Non-HD) | macOS High Sierra | 2.6 GHz Intel Core i7 | 8GB RAM | 7200rpm SATA Drive | iLok Cloud | Line6 POD UX2 | 256 Sample Buffer | 1 GB Cache |
Noise Blast - Possible Trigger? | teedeecee | Pro Tools HDX & HD Native Systems (Mac) | 2 | 02-15-2016 03:46 PM |
White noise blast | Curt Mitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-29-2010 06:13 AM |
M-box Noise Blast Problem | make haste | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-18-2006 09:55 AM |
Blast of noise 002 :o | Eman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-29-2006 10:20 AM |
