Recording latency question
I've got a session up and playback engine buffer set at 64.. It's PT 11.3.1 by the way. I've disables all plugs because even at the lowest playback level, I've still got latency problems when recording vocals. It seems there's still a delay running somewhere but I don't have any tracks hidden. I'm a little perplexed. Does anyone have any thoughts? Thank you so much,RichrdC
Re: Recording latency question
Have you tried to uncheck 'delay compensation' in the options menu ?
In some instances, this may help.
Rob ____________________ |
I get it too - 11.3.1 - i can get away with a couple of plugs but if I start adding more I get latency. It helps if I don't use aux tracks. But I try to do the session recording wise then mixing/adding plugs 2nd. I know it's difficult cuz I forget sometimes. Delay compensation helps when there are plugs but just turning it off does nothing at that point.
Isn't a problem on my HDN system. Which interface are you using?
Hdn Omni - Mac Pro 12 core lotsa poop
I always wonder if I'm missing something |
Probably yes, but what it is cannot be resolved with this little information.
I have success monitoring 256 buffer at 48k, for the pickier artists 128 is always fine. If there is a latency problem having 64 buffer, the problem is surely somewhere else than the buffer setting.
Richard, try bussing the the main out of the record tracking to the main output path. IE: not to an aux sub group. I find this helps.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Does your MIX window show the delay numbers? What is it showing? I am getting this same issue on random sessions. The worst plugin loaded shows 7 samples of latency, but several tracks are reporting 2048(plus or minus) samples of compensation for no apparent reason. I turn Delay Compensation off and go about tracking without issue, but it certainly is annoying, and makes no sense. Glad I'm not the only one
HD/Native with dual HD IO. All sessions are 24 bit/48K. Already checked for hidden tracks
If any track reports more latency than playback buffer, there is a plugin to be removed
Update,
Thanks for the thoughts.. Nothing I do seems to matter. I've tried all the suggestions and thanks so much. For a duffer like me it's great to read and work with your possibilities. To me it sounds like the Time Adjusting Delay plug but I don't have a delay on the session. Albee, Your question about my mix window showing the delay...? I'd love to know where to look in order to tell you.. I couldn't tell any difference with the Delay Compensation checked or not.. I haven't noticed this in other sessions, but I can't say it doesn't happen. Thanks everyone |
Question about compensating for latency while recording. | Funk-O-Meter | Pro Tools 10 | 2 | 06-20-2014 12:00 PM |
Recording with Amp Sim & latency question | PMcC | macOS | 10 | 08-06-2012 08:34 PM |
low latency recording vs low hardware buffer size recording | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 01-27-2009 06:49 AM |
Quick Question Latency in Recording | nightshadecrisis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-06-2003 10:21 PM |
Whats the difference between Low Latency recording and recording on low latency with | Dead River Studio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-25-2002 01:22 PM |
