micing question
i have a real nasal sounding vox and i was wondering is there a certain way
to position the mic so i could reduce the nasal parts, or is there a plug that would help reduce it maybe 30-40 percent? for demo of whut im talking about go here : song is client - sbag www.myspace.com/fmproducts42
Gear> C8, 002, Trigger Finger, Kontrol 49, Apc 40 SW > Pt 8, Reason 5, Recycle 2.1, Ableton Live Suite 8.02 Plugs > All Registered plug in's & Vinyl out the wazoo. Mp3 sucks |
Re: micing question
Waves has a De-esser that can be adjusted all over the place so I bet that could be set to squash just the nasal range of frequencies. Experiment with different mics and position and you should be able to find a setup that helps. Maybe try singing slightly off to one side of the mic instead of straight on.
Re: micing question
What mic and pre are you using? The sound starts there first.
Re: micing question
it sounds like you bounced it at a low quality. As far as nasal goes, you should try a different mic. you could try rolling off some of hte mids or using a 1 band eq.
Micing troubles | PTgeek911 | Tips & Tricks | 2 | 07-19-2005 06:53 AM |
General micing question (request for opinion)... | xeetstreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-01-2004 12:43 AM |
How do you go about micing things up? | GothicV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 10-09-2004 07:12 PM |
Question about micing cab with NT1 | fabpab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-29-2004 01:10 AM |
best mic for micing toms?? | jacko32 | Tips & Tricks | 28 | 11-17-2002 09:06 PM |
