Structure LE problem importing Kontakt libraries
I installed Structure LE over the weekend. The built in libraries work great. As I tried to import some other 'supported' formats I noticed some issues. I wanted to see if anyone else had noticed this or if it's just my system. (MacBook Pro, PT 7.3.1, OSX 10.4.10).
EXS24 libraries work OK. Kontakt libraries import, but are all monophonic (regardless of settings) Has anyone else seen this? If it's something I need to change on the library to re-save it I will, but I can't find a setting to change this (in either the parts or the patch). And another thing I've noticed that I don't like: If I try to import a set of samples that are not multisamples (first I noticed was on a set of different vocal 'snippets') and the number of samples exceeded the number of keys available then it will map multiple samples to a single key. It wouldn’t be a big deal except for the fact there is no count of samples in the browser window (where I was loading them from). Just the names. I had to guess how many samples I was dragging over to make sure that it wouldn’t map two samples to a single key. I guess I’m saying it would be nice to get a confirmation asking if you want to have multiple samples map to a single key (when mapping chromatically) if the number of samples is greater than the number of keys available for mapping (depending on the settings chosen). Or maybe add a column to the browser window that shows the sample number (starting at 1 and going up) so if I know I have 88 keys available (or less depending on which key I start on and if I use black keys) I don’t try and drag more samples than what I know is available. Just a thought. James Abbott
James Abbott 002, ProTools 7.3.1cs5, MacBook Pro Strike, Structure LE, Xpand, McDSP, Reason More money than talent! |
Converting Sample Cell libraries to Kontakt | shakti | Digidesign Hardware & Software | 7 | 07-27-2023 07:24 AM |
Encrypted or unencrypted Kontakt sound libraries | sonicland | Virtual Instruments | 5 | 02-20-2010 04:31 AM |
Structure Free read 'unencrypted' kontakt 2 libraries | Socrates | Virtual Instruments | 0 | 05-05-2009 02:23 PM |
Structure- Problem Importing Kontakt files | miked45 | Virtual Instruments | 7 | 01-21-2009 02:24 PM |
Importing other libraries into Structure | PeterB | Virtual Instruments | 0 | 09-20-2007 10:04 AM |
