Old 01-10-2024, 09:46 AM
musiclee musiclee is offline
Default Re: What I would like to see in ProTools in 2024 !
how about this?
simple and useful
see attached pic..
Old 01-11-2024, 03:51 AM
Jon_Atkinson Jon_Atkinson is offline
All good stuff..!
One feature I really like in Ableton, which I'd love to also have in PT is the ability to see when audio is playing through an input, output or bus before selecting it (it actually shows a small level meter in the Input or Output dropdown menu, so you can see if it's the one you want to select)
It's kind of difficult to describe how useful this is until you've actually seen it in use... But I find it supremely handy.
You can see here that my Moog is attached to input 9, and I'm playing it and can see the small level meter dancing next to the input number. So useful
Mac Pro 2019 3.5GHz 8 Core 48GB RAM
OS 13.6.3
Protools Studio 2023.12
Antelope Orion 32, Vienna Ensemble Pro 5,
UAD Quad PCIe
Old 01-11-2024, 04:29 AM
FunkzzaJ FunkzzaJ is offline
Oversampling during off-line bounce to combat aliasing/digital artefacts.
Enable choice of 1x (as is I suppose), 2x, 4x or more.
Or enable separate plugin setting schemes for real-time and bounce operation.
e.g. in a bounce operation plugin setting scheme I would then typically have non-linear dist/comp/lim/ plugs set to oversampling, and any headphone/room mix plugs turned off
This makes best use of CPU resources while
-mixing where real-time is a must
-bounce where bounce time can exceed song's time (to combat aliasing)
(DDMF Metaplugin allows for separate oversampling settings for real-time and bounce)
I dont know if this came out as clear as I hoped for. Or if it is doable. Does it make sense?
/T
Free beer tomorrow !!
- but until then -
we're stuck in the present moment
Old 01-11-2024, 05:37 AM
Originally Posted by lucione View Post
Yes. Specially, in Apple Silicon, the ability to use performance cores AND efficiency cores.
My God, no... leave the eff cores alone
Old 01-11-2024, 04:32 PM
stevegalante stevegalante is offline
Originally Posted by Jon_Atkinson View Post
All good stuff..!
Interesting ! For sure it has to be done with a different graphic representation otherwise you might not know if the channel is in input mode or it's just the preview
http://www.stevegalante.com
Old 01-11-2024, 04:35 PM
/T
For sure it makes sense ! The only problem I see is that nowadays many plugins let you oversample (or they do it internally), and so I don't know if this could cause conflicts or an unnecessary use of resources
Old 01-11-2024, 04:36 PM
Originally Posted by musiclee View Post
how about this?
simple and useful
see attached pic..
You mean the time remaining ?
If so, maybe it's kind of difficult to implement because the complexity of the song varies throughout the song itself, so maybe it's not totally predictable ?
Old 01-11-2024, 04:37 PM
Another little thing I'd love to have is an "Duplicate and make inactive" option with tracks and channels.
Old 01-11-2024, 09:23 PM
grayter1 grayter1 is offline
The ability to lock track heights. I don't need EVERY track to get bigger or smaller when I only want to change the size of a few.
My efx return tracks can be locked to micro or mini and remain that way unless I need to write automation on them.
Reaper added this a while back and it's incredibly useful.
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
Old 01-11-2024, 10:27 PM
massivekerry's Avatar
massivekerry massivekerry is online now
tg
If you only want to change a few track sizes, select clips/data on those tracks in the Timeline/Edit Window, and use the Track Size shortcut (I don’t recall that atm, bc I use a EuCon softkey for it). I only realized that recently (after 30 years of using Pro Tools). It seems like a dated workflow, but it does work, once you wrap your mind around it.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Runnind PT 10 and 003 Factory with NEW 2024 Mac PRSWILL macOS 20 01-18-2024 07:08 AM
[FS] $350 [104 Waves Plugins] SSL CLA API Puig Tape DIAMOND Vinyl OMNI Abbey WUP 2024 Electronic1982 Buy & Sell 2 12-05-2023 02:35 PM
[FS] $299 [28 Waves Plugins] SSL CLA API Puig Tape Vinyl OMNI Abbey Kramer WUP 2024 Electronic1982 Buy & Sell 0 11-26-2023 01:58 PM
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
