Old 01-05-2024, 10:04 AM
thin ice thin ice is online now
Default New Markers Bar
Without wishing to seem ungrateful, is it possible to revert to Classic Markers? It is just extra visual clutter that I don't need.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 01-05-2024, 10:07 AM
its2loud its2loud is offline
Default Re: New Markers Bar
Which part of Classic Markers? Do you mean the Window or the lanes?
Old 01-05-2024, 10:14 AM
musiclee musiclee is offline
whyis it even in new markers, you cannot start a new line of text in COmments section of memory markers
tab to new line?
is it me or is that crazy you have to. just type it all in 1 line?
i want to do a bullet list, or whatever, Avid? anyone??
Old 01-05-2024, 11:53 AM
Tweakhead Tweakhead is offline
+1.
and ability to hide or move that new first column in Memory Locations.
Old 01-05-2024, 03:53 PM
BScout BScout is offline
You can hide the new marker rulers (as many as few as you want -- well, up to 5.)
It's in the same drop down menu as all the other hide/view of the rulers. (you can also rename them)
The column in the marker window is something different.
Or the search area in the marker window.
But the poster is using such generic terms I'm going to assume it's about the new rulers.
Old 01-08-2024, 04:46 AM
I just meant the floating window that was a simple click to locate, or select a section to bounce. It used to be perfect.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 01-08-2024, 04:49 AM
Originally Posted by Tweakhead View Post
+1.
The problem with that is you now need that first column to select an area to bounce. It no longer works by holding shift and selecting 2 marker names.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 01-08-2024, 06:53 AM
I have never needed that capability. I always have a marker called "Mixdown Range" with only a time selection so that my mixdown is always my preferred exact length. Either way, it should be an option for all users, not forced on us.
Old 01-08-2024, 06:59 AM
man, it doesnt work for me either, holding shift. and choosing 2 markers, it used to select area, and i used it ALL THE TIME to bounce, at least 30 times a day
i am running Sonoma though, so not sure if this is specific to this "unsupported OS"
you running Ventura? can someone with Ventura try and report back?
Old 01-08-2024, 07:58 AM
I honestly don’t understand why so many people are thrown by this issue. Why do you want to do so much mouse clicking to make a selection between markers?
Use the numpad with shift to select between markers. .3., hold down shift, .4. Selection made.
'Markers Follow Edit' should not delete markers. JingleDjango Pro Tools 6 09-16-2023 01:21 AM
Beat Markers Appearing As Elastic Audio Markers Fabdickson Pro Tools 9 1 03-06-2012 05:03 PM
How to turn all Event Markers into Warp Markers ??? fman Pro Tools TDM Systems (Mac) 15 04-29-2011 01:46 PM
All Event markers to warp markers? audioluche Pro Tools TDM Systems (Mac) 9 01-11-2010 06:02 AM
PT6 Markers... GW Pro Tools TDM Systems (Mac) 1 03-04-2003 12:47 AM
