Clean install - deleting old Library files
Just spent a few hours cleaning up my new Mac as part of my clean install process, whereby I was still carrying lots of old files/folders that are no longer required/relevant. Ideally, I'm aiming to only install Apple Silicon apps/plug-ins and, whilst I plan to retain backup copies, there's lots of old software that won't be installed at all.
However, I cannot delete the sub-folders within my ~/Library/Audio/Plug-Ins folder - these are Components, Digidesign and VST, out of which I guess that Digidesign shouldn't be required in future. Not an issue of e.g. space but just wondering why these cannot be deleted, whereas their equivalents in the main Library folder can, for example? Might be something obvious ... maybe just tired?! :) |
Re: Clean install - deleting old Library files
Total guess but maybe disk permissions are not set correctly(restricting what you are able to do)
Be careful here. If this is a new Mac how did stuff get onto it that needs to be removed? With any new major upgrade, you are much better off re-installing what you need from the latest installers.
And the odd empty directory scattered in places takes no real space and you never know if some uninstaller or other software might assume it's there so best to just leave stuff alone. Especially under the mess that is ~/Library. As for why you can't remove stuff, these directories are just macOS directories protected by ACL permissions with "everyone deny delete" set. You can see this by looking at the ACL permissions with ls -lde <directory name>. (edit: sorry I had mistyped the e aka "extended" option as s). If you really really really need to delete them you can change the ACL permissions or just blow it away with sudo rm -rf <directory name>. But you should be questioning why you are going this. Be careful removing VST/VST3 or even AU plugins from /Library/Audio/Plug-Ins/* or ~/Library/Audio/Plug-Ins/* even if you do not have any DAW or other audio apps that use these plugins directly. Pro Tools might be using say VST plugins if you specifically use VST host software like BlueCat PatchWork, but also some AAX plugins use direct wrappers for VST plugins, and you need those VST plugins installed for the AAX plugin to work. Some of the plugins obtained directly from AIR Instruments do that for example. Some non-obvious non-DAW audio apps on Mac might install AU plugins since this is all so closely tied to CoreAudio. And don't mess with /Library/Audio/Plug-Ins/HAL these are CoreAudio driver components, either to implement audio routing like ProToolsAudioBridge or part of the new (user space audio drivers) AudioDriverKit software. Some installers or uninstallers may later barf if you have removed stuff by hand or changed file permissions. It can be better to use an uninstaller to fully remove traces of a plugin if you really want to get rid of it, but not all plugin vendors are great about that either. But running an installer and picking not to install say AU and VST plugins is great if you don't need them, the installer should knows if say an AAX plugin would rely on a VST plugin being installed, etc. For almost all applications and plugins and libraries you don't get to pick Intel or Apple Silicon native support, they are both built into those files at a low level and you don't mess with that. So again a clean Mac or clean macOS install and just install the minimum needed software is often the best way to go. Last edited by Darryl Ramm; 12-17-2023 at 06:33 PM. |
Cheers Darryl - used Migration/Setup Assistant to transfer my user account from old Macintosh HD (in a drive enclosure) without transferring any applications. Decided on this approach versus recreating the account and transferring data manually, in order to avoid manually setting UIDs/GIDs, which you previously guided me on also. I ran some tests using a separate MacBook Pro and my original account used/allowed uppercase character(s) whereas new accounts did not, so I wasn't convinced that everything would match without resorting to further tweaking. Quote:
Thanks for the awesome, detailed advice - I also like to add my detail here in case it helps others in future! :) |
Great stuff.
I forgot to mention one very nice article on ACLs from Howard Oakley: https://eclecticlight.co/2022/02/16/...sions-and-acls A nice promotion of Tinker Tool. Oakley posts so many useful deeper Mac articles. ACL capability can be a bit to learn but it is needed to make modern computer systems really work with usable security/permissions. Windows, Linux, and macOS all support ACLs with similar capabilities/behavior. |
What was said about VST plugins is something I experienced. Omnisphere stopped working when I deleted the VST3 plugin that I assumed Pro Tools wasn't using. A few other instrument plugins were exactly the same.
The frustration of Mac System Data grabbing over 120gb of my drive is what lead led trying to clean things out of Library folders, but you have to be quite careful. The only thing I ever managed to do safely was delete Time Machine Snapshots to save any space. For some reason they start writing to my system drive, even though I use and external drive for TM.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 Last edited by thin ice; 12-18-2023 at 06:10 AM. |
That's why clean install (yes, wiping whole hard drive) is recommended every now and then. Especially now when one of your goals is to only install ARM compatible apps and plugs.
Picking up + seconding Darryl's recommendation of The Eclectic Light Company, I have learnt and decided to start a new Time Machine set for my new Mac as inheriting my longstanding/full history which commenced pre-APFS (for Time Machine - initially, only HFS was compatible) wasn't viable. |
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
... this should explain properly ...
https://eclecticlight.co/2016/01/01/...cal-snapshots/ https://eclecticlight.co/2020/07/29/...and-snapshots/ https://eclecticlight.co/2022/02/15/...ine-snapshots/ Hope that helps! |
What files to transfer for PT LE 8 on Snow Leopard clean install | sturdystrutter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-18-2016 02:01 PM |
Mavericks Clean install. PT LE8 user. What files to transfer? | skronger | macOS | 23 | 06-09-2014 05:05 AM |
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! | shamanrock | Windows | 13 | 12-27-2012 04:39 PM |
Clean install of PT 10 under fresh install of Lion | bortraws | macOS | 0 | 10-24-2011 08:53 AM |
Can't install Pro Tools 8! Clean install, new system, Vista! | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 01-09-2011 11:16 AM |
