New Markers Bar
Without wishing to seem ungrateful, is it possible to revert to Classic Markers? It is just extra visual clutter that I don't need.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
Re: New Markers Bar
Which part of Classic Markers? Do you mean the Window or the lanes?
Re: New Markers Bar
whyis it even in new markers, you cannot start a new line of text in COmments section of memory markers
tab to new line? is it me or is that crazy you have to. just type it all in 1 line? i want to do a bullet list, or whatever, Avid? anyone?? |
Re: New Markers Bar
+1.
and ability to hide or move that new first column in Memory Locations. |
Re: New Markers Bar
You can hide the new marker rulers (as many as few as you want -- well, up to 5.)
It's in the same drop down menu as all the other hide/view of the rulers. (you can also rename them) The column in the marker window is something different. Or the search area in the marker window. But the poster is using such generic terms I'm going to assume it's about the new rulers.
Re: New Markers Bar
I just meant the floating window that was a simple click to locate, or select a section to bounce. It used to be perfect.
Re: New Markers Bar
The problem with that is you now need that first column to select an area to bounce. It no longer works by holding shift and selecting 2 marker names.
Re: New Markers Bar
I have never needed that capability. I always have a marker called "Mixdown Range" with only a time selection so that my mixdown is always my preferred exact length. Either way, it should be an option for all users, not forced on us.
Re: New Markers Bar
i am running Sonoma though, so not sure if this is specific to this "unsupported OS" you running Ventura? can someone with Ventura try and report back? Last edited by musiclee; 01-08-2024 at 07:27 AM. |
Re: New Markers Bar
Use the numpad with shift to select between markers. .3., hold down shift, .4. Selection made. Last edited by its2loud; 01-08-2024 at 08:08 AM. |
'Markers Follow Edit' should not delete markers. | JingleDjango | Pro Tools | 6 | 09-16-2023 01:21 AM |
Beat Markers Appearing As Elastic Audio Markers | Fabdickson | Pro Tools 9 | 1 | 03-06-2012 05:03 PM |
How to turn all Event Markers into Warp Markers ??? | fman | Pro Tools TDM Systems (Mac) | 15 | 04-29-2011 01:46 PM |
All Event markers to warp markers? | audioluche | Pro Tools TDM Systems (Mac) | 9 | 01-11-2010 06:02 AM |
PT6 Markers... | GW | Pro Tools TDM Systems (Mac) | 1 | 03-04-2003 12:47 AM |
