Problem: Seamless audio transitions
Hello Pro Tools users,
I am pulling my hair out with a strange unanswerable challenge. I'm finalizing an album where each track flows into the next without silence or edits. I blend each track into the next, sometimes via sound collage between songs. When I play both tracks pre bounce there is no click or dip in audio, the transition is seamless. However once I've bounce the tracks into one stereo file this new bounce has a tiny dip down in audio, thereby creating a tiny click or dip in sound. Hoping this is just a setting that I can adjust, I can't make sense of why this should be happening. I know how to use fades, but this is creating a tiny fade where there was none. Thanks, Frankie |
Re: Problem: Seamless audio transitions
Its not clear by your description what the end goal is here. Are you trying to make a CD or is this for streaming, or some other destination. Some things to consider:
1-if you want to make CD's, what program are you using to create a DDP or for burning your own? 2-if this is for streaming, check with whatever service you plan on using as usually(my understanding) they will expect each song to be an individual file(making the flow you want maybe something impossible?). 3-maybe you are trying to do something in Pro Tools that its not designed to do? Presonus Studio One or Wavelab(even "essentials") might be a better option?
How are you transitioning between them..? If you're crossfading it may be the fade shape..equal gain vs equal power...equal power is usually smoother except on some low frequency heavy material.. post a pic of your timeline showing one of the transitions
This is knowledge that I gleaned from a long-ago post on this forum. All due credit to the originator, who I'm sure I could find after hours of searching, but here it is: The clicks you're experiencing between songs is a result of making cuts between audio frames. I won't go into all the math involved here, but if you put the session in Bars/Beats and set the tempo to 4/4, quarter note = 281.2500, turn on Grid and make all cuts on the grid your clicks should disappear. Let us know if that solves your problem. If not, I may also have misunderstood the issue.
Bob Without a song The day would never end |
Also if this is from a CD burn, make sure to burn in DAO (disk at once) mode not TAO (track at once).
If this is occurring in a media player, the media player is at fault. MP3 compression breaks seamless playback between tracks. When you hear it and it seems to be seamless, it’s because the player overlaps playback slightly. Sent from my iPhone using Tapatalk
smooth clip gain edit transitions? | oldskool | Pro Tools 2020 | 6 | 03-09-2021 01:02 PM |
Free glitch & transitions fx sample pack v.n | sunder3213 | General Discussion | 0 | 10-16-2018 08:01 AM |
Smooth out Automation Transitions | Dizzi45Z | Pro Tools TDM Systems (Mac) | 0 | 03-01-2012 07:40 PM |
Seamless Compatability... | bestPosterEver | Pro Tools M-Powered (Mac) | 1 | 06-08-2005 11:39 AM |
Transitions | gk | ProControl, Control|24, Command|8 | 6 | 07-29-2001 05:44 PM |
