Template (where)
First time me setting up A template and now its asks me where to save it? I saved the folder on the desk top, hope that was right?
also what's the general consensus on a new session file type, *AIFF* or BWF (WAV.)
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Re: Template (where)
I haven't used this feature yet, but it seems like you'd want to save it to the audio drive because it basically becomes a session like any other session (a PTF file). You can just resave it this way and trash the one on your desktop.
And WAV files are the most universal, if you really want to be safe. |
Personally, I save to the System under a User Template folder, as the Pro Tools Session Templates (.ptt) folder does in fact reside on your Local Disk (System Drive). Even when you uninstall Pro Tools the Session Templates folder is still present thus giving you the best location to save your user templates, IMO.
Aaron Mulqueen - 001 HD Native |
You used to have to use the Mac "Stationary Pad" feature to use templates but now it is integrated. My feeling is you should save it to "the system" option and just create a new category if the stock ones don't work for you.. That way it will be available from your startup screen (new session from template). Good to know that according to filo it is saved in the case of an uninstall.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Also I tried a session with the WAV. but it wouldn't play on Itunes?
I don't mean the system drive, I mean the option from within the "save as Template..." pop up. This is the top radio button in that window. It shouldn't be on the desktop, it should be in the Applications/Digidesign/Protools/session templates/<sub-folder>
Are you being presented with this window:
http://i608.photobucket.com/albums/t...astemplate.png http://i608.photobucket.com/albums/t...stemplate2.png If so, all those different categories are just folders in the Session Templates folder.. If you make a new category then it should create a new folder there and allow you to save your template there. If this is not what you are seeing then I'm not sure what the problem might be... Are you using PT8?
BFD Template ? | Sam C | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-16-2009 11:40 AM |
Template | DSG LABEL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 12-16-2008 02:14 PM |
when using a template? | chazzo03 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-21-2008 09:06 PM |
Template set up in PT7.3 | zoing123 | Post - Surround - Video | 6 | 05-10-2007 02:05 PM |
Template ? | new engineer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-04-2005 06:04 PM |
