Old 05-21-2009, 03:53 AM
levelaudio levelaudio is offline
Default lo-fi plugin stops working
Occasionally when I am working in a session with the lo-fi plugin on a track, I may change another plugin on that track, move the lo-fi plugin up or down a slot, or make some other change in the session, then suddenly the plugin stops working completely. The presets don't load, the sliders don't work, it doesn't have any effect on the sound. I think this may be the case with all the d-fi plugins (sci-fi & recti-fi too), but only recall seeing it with lo-fi since I haven't used the others much recently. Currently the only workaround I've found to resolve the problem is to quit Pro Tools, power cycle the DIGI002, and restart Pro Tools.
I'm on Pro Tools LE 7.4 on a dual 2GHz G5 Power Mac (PPC) with a DIGI002 Rack, and the session is a 48KHz 24bit format.
Any help is sincerely appreciated. Thanks!
Old 05-21-2009, 05:50 AM
The Dougfather The Dougfather is offline
Default Re: lo-fi plugin stops working
That set is audiosuite only.......isn't it?
If audiosuite isn't working make sure the use in playlist button is pressed and higlighted white.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 05-21-2009, 05:58 AM
daeron80 daeron80 is offline
No.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 05-21-2009, 06:46 AM
It's the lo-fi RTAS version on an audio track that is having the problem. I haven't tried the AS one to see if the same thing happens to it when the RTAS plugin won't work.
Old 05-21-2009, 10:44 AM
DigiTechSupt's Avatar
Have you tried trashing preferences yet? Which version of those plug-ins do you have installed? Have you verified that ALL installed plug-ins are compatible?
Avid Audio Tech Support
Support FAQ
Softsynth stops working Dave Modisette Pro Tools 11 8 02-16-2014 09:58 AM
7.3.1cs4 - Tab key stops working bad jitter Pro Tools TDM Systems (Mac) 7 07-28-2012 07:22 PM
Tab To Transient Stops Working ronstephens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-29-2010 04:41 AM
Tab to transinet stops working in 8.03 garnoil Post - Surround - Video 0 01-05-2010 08:07 AM
7.2 -- what stops working? brucecoughlin Pro Tools TDM Systems (Mac) 2 08-29-2006 12:05 PM
