Output from PT to analog desk?
Is there any other solution (ie cards that might work) to get the 24bit Pro tools session mixed externally, other than having a stack of 888s? I have an adat Bridge (and so on) but the lightpipe won't help much with an analog desk's Iinputs. I guess I'm asking, is there a cheapy way of doing this for the customer who wants to mix the session externally?
TIA |
Re: Output from PT to analog desk?
apogee DA 16
RME ADI-8 DD [img]images/icons/rolleyes.gif[/img] |
Frontier Design Tango is an option. It will convert eight channels lightpipe to eight channels analog.
Jerry Nashville, TN |
No, the Apogee DA16 is actually ideal. You have an ADAT bridge, and the DA16 converts lightpipe to Analog outputs. It's great, because you get 16 Apogee converters with a relatively low price, and your ADAT Bridge can stay useful.
Sorry,
what I meant was - is there a converter that will take the PT output and convert is to analog for feeding to an analog consol e without fancy adat connections etc. The RME appears to be a format converter in the digital domain. TIA |
Lumpo there is no way you can mix eternally to a desk in PT without an interface of sorts, now if you already have an adat bridge you will need a lightpipe to analog out box like rme adi pro which according to loads of people here sounds way better than an 888 interface its only 8 i/o so you would need 2 of these if you want 16 i/o bear in mind rme also has 8 analog ins, I own an adat bridge and decided to get that against the digidesign 1622 interface which is 16 analog i/os purely because i could always change the front end a/d convertors if need be, i currently use an adat xt20.
Good luck |
Can I send frm analog outs 3-8 002 desk to headphones | humpeedumpee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-26-2011 05:37 AM |
HD1 + 96i/o + analog desk | Benjamino | Pro Tools TDM Systems (Mac) | 1 | 06-08-2010 11:55 AM |
Controlling an automated analog desk via MIDI from Pro Tools | barish | MIDI | 4 | 03-13-2007 11:59 AM |
Interfacing 888 analog output with analog console | Siegfried Meier | Pro Tools TDM Systems (Mac) | 3 | 09-12-2003 01:26 PM |
Analog desk via control surface? | tlester | Pro Tools TDM Systems (Mac) | 7 | 04-29-2003 09:50 AM |
