Old 12-21-2015, 02:50 PM
shill1970 shill1970 is offline
Default Pro Tools 12 hangs on "initializing database" when loading
Pro Tools 12 hangs on "initializing database" when loading.
I've tried running Pro Tools 12 with and without my virus protection running.
In both cases it gets stuck in "initializing database" step and I never am able to access the menus.
When looking at the event viewer I get the following message:
Detection of product '{D06966A5-E970-4DBD-88D8-4B10C5ED5623}', feature 'Application', component '{80A8532C-1FC8-4912-8659-CD8A02277005}' failed. The resource 'C:\Program Files\Avid\Pro Tools\SMgr_Resource412.dll' does not exist.
I also get a simular message when trying to run a "repair" on Pro Tools.
Old 07-20-2017, 11:29 AM
jamesregan jamesregan is offline
Default Re: Pro Tools 12 hangs on "initializing database" when loading
I'm having a similar issue, it's taking about 4-5 minutes before it finally launches.
Never had a startup issue like this in the past. It only seems to happen after the computer re-starts. PT starts up fast if you quit and open it again if you DON'T re-boot the computer.
Old 07-20-2017, 07:45 PM
peaklimit peaklimit is offline
It seems to be a Workspace related. Trashing the files will help but then after rebuilding them it will still be slow.
Having rebuilt I have repeatedly tried to Recalculate Waveforms but this always crashes supposedly due to a lack of RAM..... which there isn't.
Old 08-16-2017, 10:00 AM
SomeDude SomeDude is offline
Ive been having the same issue since i went to 12.8. It'll relaunch fine after it goes through the initial 5 minute startup, until you restart the computer then it happens all over again. Very frustrating.
Old 08-18-2017, 06:45 AM
mbafmike's Avatar
mbafmike mbafmike is offline
I have unfortunately the same issue going on since the 12.8 Update.
For minutes I see only the PT-Logo, which takes forever.
After closing and reopening PT without restarting the computer all works normal.
MacPro running Sierra 10.12.6
Old 08-18-2017, 09:59 AM
oldskool oldskool is offline
Just for the record I have this same problem. While "Launching Pro Tools" the first time after a cold boot Activity Monitor reports a lot of disk read activity. Additionally, this may or may not be related, but the Pro Tools Quicktime server remains hung during and after PT startup.
This behavior began immediately upon the upgrade to 12.7 on both of our systems.
Old 08-18-2017, 10:33 AM
john1192 john1192 is offline
may i ask, are you folks seeing a hang on particular plugins or any process that is showing on the Startup Window ??
just trying to see if there is any correlation between your experiences ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 08-18-2017, 03:38 PM
PT pauses for many minutes while "Launching Pro Tools" is displayed. Loading plugins goes by quickly just like in 12.7
Old 08-18-2017, 04:57 PM
I found the solution in another thread. Installing new iLok licensing manager fixed the slow boot.
Old 08-19-2017, 05:30 AM
good to hear ...
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Pro Tools Startup Hangs on "Initializing Databases" Tomcom403 Windows 19 11-07-2016 04:48 PM
PT10 hangs on "initializing databases" pianosdr Windows 13 11-02-2015 09:44 AM
Pro Tools 11 hangs up at "loading midi engine" step for 10 minutes kevinjrowe macOS 0 08-23-2014 12:25 PM
Pro Tools SE lags infinitely at splash and says "initializing databases" dietermoreno Pro Tools SE and Essential (Win) 3 02-03-2013 01:22 PM
HELP - PT9 HD won't boot, hangs on "initializing databases" IndreStudios Pro Tools TDM Systems (Mac) 1 11-15-2011 11:50 AM
