Ocean way drums stand alone questiob
I got a hold of Oceans way a couple years ago and I like the sounds but I have felt limited trying to get the response I need to play them with the td 20. I feels like the midi is sluggish as compared to if I just record audio out of the td -20... I have only used it as a plug in with Pro tools..
I have not ever used it as a stand alone. Can you record midi with it stand alone? then import the midi files into pro tools or can you record audio in stand alone. Another option I am thinking about is drumagog.. record audio and then use drumagog.. does anyone know if you can use oceans way with druma gog? |
Re: Ocean way drums stand alone questiob
When you say sluggish, do you mean that the note comes later than when you hit the pad? If so, it might be a latency problem and you need to adjust the hardware buffer in Protools to a lower number. 64 or even 128 should work.
I don't latecy is it. it is not like i hit it and there is a delay,, just seems like i do not get the response i want. If i go audio out it is like i am freeed up more.
as far as fineese.. It seems with the mdi it is more rigid to the grid i guess |
You mnetion VST,, I am using Pro tools and will it work RTAS ?
Drumagog 5 can work as an RTAS plugin in Pro Tools. But when Drumagog 5 Platinum itself is hosting a plugin, it hosts VST instruments no matter what DAW you're using it in.
OH,, Ok,, I am still somewhat of a novie i guess so I just thought since I was using pro tools..That might be what I want to do. get the signal for the individual drums tracks which I have 8 seperate out puts then I would insert the drumagog on each track i guess? And I could access the ocenas way? could youlet me know if I am on the right path on what I am thinking
Yep, that's exactly the right path. Just make sure you split all the outs for each drums separately to its own track. Then you'll use Drumagog 5 Platinum to host Ocean Way without having to bouncing to MIDI.
Check out the demo to test drive the feature! |
Ocean Way - Issues Saving Sounds | viktor99 | Virtual Instruments | 3 | 11-02-2013 04:40 AM |
Making the drums stand out in a mix | MarkH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-11-2010 08:05 AM |
Group Buy of Ocean Way drums alert | Thuneau | The Drum Room | 5 | 12-08-2009 08:11 AM |
Ocean Way Drums or Mixosaurus Drums | Dog BBQ | The Drum Room | 3 | 10-09-2009 04:32 PM |
ocean wave hiss when recording | mahoney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-28-2004 12:57 PM |
