Cannot get sound from 003
Anybody please. PT recognizes the 003 in the hardware section, mute is off and Core audio manager says: not connected (HW in use).
Please, does anybody have any ideas?
Mac Pro 2x2 GHz Dual core; RAM 6 GB; OSX 10.6.3; PT LE 8.0.3; Digi 003 console; MPT2; BFD2; Stylus RMX 1.9 |
Re: Cannot get sound from 003
Not sure off the top of my head.
Have you tried this - With the unit off hold down 'Aux In->7/8' and the 'Mute' button (next to the Monitor knob), and then turn on the power to the unit. On 003 you'll see the display say "Load Firmware" and the MIDI Lights (In, Out1, Out2) will all start flashing. The MIDI lights flashing is the only indication on the 003 Rack that the unit is in this mode. Once it is in this mode, launch Pro Tools, and you will see the message, "003 has firmware version x.xx, do you want to update..." Click the Update button to upload the 003 firmware. |
Thanks for that daveoverreal. Tried it and still not working,
Are you running itunes at the same time, or any other application that may be competeing for core audio? I have trouble when I use itunes at the same time PT is open. Another question...are you running the core audio stand alone driver? I don't think that should be running with protools, only if you are using another DAW with the digi hardware, so if that is opened, then that may be why it is saying it is in use by another application.
Please read the Core Audio Usage Guide from our website. For the original poster - have you tried trashing preferences yet? Which port on the computer is the 003 connected to? Have you tried a different port or cable? What type of hard drive are you using for recording/playback? Please see the General Troubleshooting thread for other possible fixes for your problem. |
Mbox Pro 3 master volume knob initial adjust jumps from no sound to sound : | | Focuret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-17-2012 04:45 PM |
Audacity Sound, Reaper Sound, Pro Tools NO SOUND | RoganX | Pro Tools 10 | 3 | 03-18-2012 09:06 PM |
MBox2Pro - Boot:No Sound; Disconnect/Reconnect Firewire: Get Sound; Why? | mav9999 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-23-2009 08:48 PM |
Skywalker Sound (Lucasfilm) Supervising Sound Editor Interview | HDFilmtools | Pro Tools TDM Systems (Mac) | 0 | 10-02-2008 03:12 PM |
MBox used as main sound card but sound is jerky | Jonny5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-03-2006 08:42 AM |
