AAF unstable?
I have been working with AAF's for a while now and they seem a lot more unstable than the OMF's I am use to. Are there any assistants out there that are having troubles with AAF turnovers from picture?
Re: AAF unstable?
I´ve used referenced AAFs with MXF audio for the last 8 months without one single AAF that didn´t open. And we did receive A LOT or AAFs.
Same is true for the reverse workflow from PT to AVID. Note that unlike with OMF PT doesn´t read pan-info from AAFs. Frank. |
Re: AAF unstable?
If youre using AAFs, chances are you're in an Avid workflow. Problem is, there are some "Send to Pro Tools" commands that have the wrong settings in the Avid file menu. To get the right sort of AAF, your video editor really needs to understand the options in the export menu, options like "copy and relink" to a shared volume or trackpack being preferred to simply "linking", and making sure to "render all effects", but not to transcode video to QT if you have a mojo attached to your PT rig. Those sorts of things often get selected incorrectly, leaving you with potentially an AAF that PT wont like.
If you are reguarly getting material from one avid suite, its definately worth going over there and checking the export options they are using and saving it as a "Send to jackisdead" preset, to remove potential user errors from freelancers and the like. Makes the workflow less stressful for the video op too. You may already be doing this, if so, apologies, but in my experience alot of avid video ops dont even know there is an option except "Export", theyve never used the "Send to" commands or even looked at them, but theyve been there for over 2 years now. Hope that helps. |
Why is PT so unstable for me? | typhy | macOS | 1 | 07-31-2012 12:55 PM |
PT 9.0.5 - so unstable | anackman | macOS | 4 | 10-24-2011 01:09 PM |
Why is PT 9 so unstable? | tblythe.sound | macOS | 44 | 05-07-2011 02:19 PM |
Unstable | HDK_Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 03-11-2010 09:02 PM |
Mac? Unstable? | link | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 05-05-2000 03:57 AM |
