BFD in Leopard
I was kinda hoping I could use BFD, XFL, and all other plugins in Leopard, like orca etc, and not ONLY BFD2. Is this possible?
Protools 9, digi 002 rack. CPU: Core i5 760 RAM: Lynnfield, 4GB DDR3, P55-chipset, LGA 1156 Cooler: Master CM 690 II Advanced Sort Graphic: XFX Radeon HD 5870 1GB GDDR5 System HD: Crucial RealSSD C300 2,5" 64GB Storage HD: 500 GB External HD: 500 GB Op system: Microsoft Windows 7 Home Premium NO OEM, 64bit |
Re: BFD in Leopard
Aaron Mulqueen - 001 HD Native |
Re: BFD in Leopard
Thanks for the answer. I guess they put BFD in secondline and hope people buy BFD2. God knows, but then I just have to use Tiger. No problemo! =)
Re: BFD in Leopard
It does seem that FXPansion is forcing its customers to upgrade to BFD2, which is concerning, but it may also be possible to get BFD1 to work. I'm able to use BFD1 with OS 10.5.1 without any problems - can't speak for OS 10.5.3. |
Re: BFD in Leopard
I've been running BFD 1.5 in OSX 10.5.4 PTLE on my G5. It works...
Re: BFD in Leopard
Hi..
I asked on fxpansion forum, this was the answer I got from rory_fx Do you mean BFD itself? If so, you should be running 1.5.47 if you use Logic 8 and 1.5.46 if you use any other host. For XFL Expansion pack, if you already have the data installed, you only need apply the audio fixes and XFL Patcher (and the bonus content should you wish). Right now I have 10.5.3, and it "works" in Protools, yet my mousepointer is jumping around abit when I move the mouse, though I ain΄t using more then 25-30 % of my cpu power. Seems like an uncompabilityproblem... I guess BFD2 demands even more cpu power..
Re: BFD in Leopard
PS: Thanks for the answers. Found a buyer, so perhaps I΄ll go to BFD2. If not, there are probably other good solutions.
Re: BFD in Leopard
im using:
OSX 10.5.3 PT LE 7.4.2 BFD 1.5.46 imac dual 2.4 intel blah blah... 4 gigs ram It works... terribly... I cant go for 15 minutes without getting a -38 error. I also get the ever-popular PNG error as well. I get errors everytime I use it. If I knew BFD2 would solve these problems, I would go ahead and make the switch... However, I've lost confidence in BFD and pro tools working well together, so I'm a bit hesitant to upgrade.
Imac Late 2013 2.9 GHz Intel Core i5 8 GB 1600 MHz DDR3 OS 10.11.2 PT 12.4.0 |
Re: BFD in Leopard
There are no PNG or VDB -38 errors with BFD2 --- for the record those are Pro Tools bugs which seem related to low resources.
Rail
Re: BFD in Leopard
If I'm having a problem with system resources, how will upgrading to a more CPU demanding BFD2 program make those problems go away? The only way I see that helping is if BFD is indeed the problem... Although you say PNG and -38 errors are problems with pro tools, BFD causes them to happen and I believe that you're kidding yourself if you don't think thats the case. Even if they are problems with pro tools, BFD is supposed to be compatible with pro tools. My system is more than adequate, especially when you consider the meager minimum specifications required to run BFD according to the documentation. I guess what I'm saying is, if BFD causes major problems (and I would call -38 and PNG major problems) that are lying dormant in a program to come to the surface, then the product shouldn't be called compatible with Pro Tools. I know I'm not the only one with an overly-qualified system unable to run BFD. With that being said, BFD is THE BEST sounding drum plugin as far as I'm concerned and I plan on upgrading if for no other reason than to fix these bugs. However, if there are some other bugs that reveal themselves only when I try to run BFD2, I will be THOROUGHLY upset.
Leopard to snow leopard clean or update install | joji | Pro Tools TDM Systems (Mac) | 10 | 01-01-2011 02:21 PM |
Snow Leopard vs Leopard - Pros & Cons | HipHopWong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-07-2010 05:42 AM |
Couldn't get snow leopard install to stabilize from leopard clone update! | crizdee | Pro Tools TDM Systems (Mac) | 2 | 01-11-2010 04:45 PM |
Native Instruments Akoustik & Elektrik Piano Compatibility on Leopard & Snow Leopard | DigiTechSupt | Virtual Instruments | 0 | 01-07-2010 11:08 AM |
If buying Imac and MBox2 tomorrow: Leopard or Snow Leopard? | Jairo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-22-2009 03:13 PM |
