How can I run 16 tracks input/output on 002 at 96K
Is there any way to run 16 tracks input/output at 96K on the 002?
I have a RME a/d converter. It has two optical inputs and two optical outputs, both of which are rquired to send/receive 8 tracks at 96K. However, the 002 only has 1 optical in and 1 optical out (which only allows you to run 8 tacks at 48K or 2 tracks at 96K). RME makes a card (Hammerfall Light) that has the two optical ports. Does anyone know if this card will work? Is there any other card that will work? Or am I stuck with having to purchase a HD system. THANKS! -John |
Re: How can I run 16 tracks input/output on 002 at 96K
I don't think it can be done.. the 002 is limited to what you described for I/O (except I think it is 4 channels via ADAT at 96k, maybe?) and PTLE will not accept any other I/O. You could also get 2 more channels in via the SPDIF for 14 total at 96k.. If I am wrong others will know...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
You are stuck with HD........the 002 can only do 10 channels at 96k. 8 regular inputs plus 2 S/PD
IF (Coaxial or Optical)..it does not support the optical format for 4 channles @ 96k. It can only do ADAT 8 channels @ 48k. randy |
The two SPDIF inputs work at 96K right? For some reason, I can't seem to get Pro Tools to select SPDIF as an input when the session is at 96K.
Input/Output buffer, Midi Tracks and buses | stargazer | Pro Tools 11 | 0 | 04-23-2013 05:53 AM |
MBox Pro 3G-no output/input | Seth Thomas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-29-2012 04:32 PM |
002 Output re-recording to Input | yeluhz_strongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-06-2010 10:31 AM |
2 MIDI Input Tracks Output to Same MIDI Channel | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-05-2005 03:20 PM |
Please help, no output / input from 001 | jdavis74 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-03-2003 07:18 AM |
