Core Audio Driver/Logic sample rate issues
Has anyone running PT7 successfully been able to use the Digi Core Audio driver with Logic Pro 7? If I select just the Digi driver and turn off DAE & DTDM, all my Logic sessions want to playback at double speed and I get "Error trying to synchronize Audio & MIDI" errors with a sample rate up around 95K found.
This kinda sucks because there are a few sessions in Logic that I need to move over to PT and I'd love to leave Logic in Core Audio mode and not have to switch these sessions over to DAE/DTDM. Thanks! don
PT Ultimate 2019.10 Avid S3 Mac Pro 6,1 (2.7GHz 12 Core, 32GB RAM, 512GB boot) macOS 10.14.4 Lynx Aurora(n)/HDX/Sonnet Echo Express III-D don gunn |
Re: Core Audio Driver/Logic sample rate issues
All i can tell you is that the sample rate needts to be set in pro tools first before opening logic!! problems arrise when you have pro tools running at 48 and then try to open logic at 44.1 etc. Another way is to set the sample rate in logic then close down logic and re boot again and this usually works! Chris
Digi Core Audio Sample Rate Problem | JB3 | Pro Tools TDM Systems (Mac) | 6 | 07-18-2013 11:50 AM |
PT9 Sample Rate with Core Audio | tvoc | macOS | 1 | 06-27-2011 01:17 AM |
How do I manually change the sample rate on 002R with Core Audio? | rastro2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-14-2008 08:46 AM |
Core Audio Driver for PT 7.4.2 and Logic 8? | logandrum | Pro Tools TDM Systems (Mac) | 11 | 11-12-2008 11:17 AM |
logic audio 4.5 and digi001 sample rate problem | ris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-06-2000 02:21 PM |
