Artist series and Win7 PT10 problems, sames as with PT9
Should I be able to see the units under my network map?
What are the Network Adapter settings and prtocols that are needed for this to work? It's near impossible for me to get the units connected to the system. They just stand still with AVID logos on them and that's it. I restart and disconnect-reconnect, power up using different order and still nothing. I have Win7 64 bit and Eucon 2.6.2, Pro Tools 10 HD. Troubleshooter of some sort is much needed for setting up Windows network settings so that these controllers could be used. I have changed the router out but no difference. If I run an Mac on the same network then the controllers will instantly work with the Mac. |
Re: Artist series and Win7 PT10 problems, sames as with PT9
JC |
I was able to get the surfaces online by disabling windows firewall!? Although I see the Eucon apps are on the green list still it seems firewall blocks the controllers for me. Is there something that might be missing from the firewall green list that would cause this? I had an impression Eucon installer will add all that is needed to win firewall so issues like this would not happen?
http://avid.custkb.com/avid/app/self..._Administrator *note, when you run all these steps, you probably have to re install all your (not pro tools) plugins so beware! Ultimatly it solved all my problems on windows 7 64 bit with Eucon goodluck let me know if it worked Martin Pieters |
Just installed SP1 but no difference. Can't go thru complete W7 reinastall, not yet, but will try that when I can afford downtime |
New Artist Series? | daChayce | Artist Series | 7 | 04-13-2014 10:10 AM |
Control Surface for PT10 - Not Euphonix/Artist series | miketeachesclass | Windows | 10 | 06-19-2012 04:58 PM |
PT10.1.2 Win7 Video scrub problems | JamesPondAqu | Windows | 6 | 05-27-2012 11:45 PM |
PT10 and Plug in mapping on Artist series | propower | Pro Tools 10 | 0 | 10-23-2011 11:51 PM |
CSCooper MCS Series vs EU Artist Series? | GrievousAngel | Artist Series | 1 | 12-01-2010 01:10 PM |
