Old 03-21-2009, 01:51 PM
jlonigro jlonigro is offline
Default PTLE 7.3.1 NO Dly display
I'm trying to figure out the insert delay after applying a plugin to a track. When I command click in the volume display of the track it just shows 0. I know there is a delay going on but why does it say 0?
Old 03-21-2009, 02:34 PM
Anangu Anangu is offline
Default Re: PTLE 7.3.1 NO Dly display
command, DOUBLE left click, i think
Mac Pro 2x2 GHz Dual core; RAM 6 GB; OSX 10.6.3; PT LE 8.0.3; Digi 003 console; MPT2; BFD2; Stylus RMX 1.9
Old 03-21-2009, 05:31 PM
musicalavtech musicalavtech is offline
What plug in? What makes you think it has a delay? Not all plugs have a delay. And as Anangu posted...Command+2 clicks shows plug in delay.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Old 03-22-2009, 08:43 AM
I have command double clicked and it shows 0. It does tis with PSP Vintage Warmer, Sonalksis Compressor, URS Classic EQ
Old 03-22-2009, 09:37 AM
Phil Ogden Phil Ogden is offline
Something wrong there as PSP VW definitely should report a delay. You're clicking over the actual numeric value right?
What about if you hold down the alt key at the same time as the command key? This should perform the same but for all tracks. At least one track plug should report a delay (usually in samples).
http://www.myspace.com/philogg
Old 03-22-2009, 04:20 PM
Yes I definitely alt command clicked in the green area on a track where volume data would be and all tracks then said 0 with no DLY.
Old 03-23-2009, 11:55 AM
DigiTechSupt's Avatar
If "Narrow Mix" is enabled, it will only show you the delay value without the "dly".
Choose View> Narrow Mix.
After confirming that it's the dly value showing "0" samples, insert a "Time Adjuster" plug-in which will allow you to control the amount of delay. Does the number of samples in Time Adjuster match what the track is reporting?
Avid Audio Tech Support
Support FAQ
Digi Tech Sup: Color Display & Aux Send Display bugs nob turner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-07-2010 02:43 PM
Weird alien crazy incorrect characters display when opening a session - PTLE 8 Growlyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-18-2009 11:51 AM
erratic/jerky screen display in PTLE 7.0 MrMike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 04-06-2006 02:06 AM
Midi display glitch on instrument tracks PTle 7.0 kRokksOn MIDI 1 03-01-2006 01:01 PM
PTLE 5.11/WinME display problem Jeff Jewett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-08-2001 02:27 AM
