Second half of the expansion chassis just went dead what gives?
Cant get 2nd half of the expansion chassis to work?
Hello Brand New Old Stock high serial# Digidesign 13-slot Exp Chassis NB0746300E also Used Magma 13 -slot Exp Chassis Just Purchased from Performance audio with retuen policy as new Chassis came complete with host and interface cards and 4' cable. Worked fine yesterday. Apple G4 Mac Tower 2003 Dual 1gig Quicksilver 1.5gig ram 0S.9.2.2 ProTools 5.1.1 TDM Mix++ and more G4 Slots 1. Radeon GeForce4 Ti 4600 128me 2. Magma host card 01-03527-00 (supplied with exp chassis) Expansion Slots i/o PCI MAgma inter 01-04626-XX Rev - Blank (supplied with exp chassis) 1.4 DigiDesign Mix Core TDM PCI 1.5 DigiDesign Mix Farm TDM PCI 1.6 DigiDesign Mix Farm TDM PCI 1.7 DigiDesign DSP FarmII TDM PCI 1.8 DigiDesign DSP FarmII TDM PCI 1.9 DigiDesign DSP FarmI TDM PCI Everything under here is missing in DigiTest! 2.4 DigiDesign SampleCellII Plus PCI TDM daughter card 2.5 DigiDesign SampleCellII Plus PCI TDM daughter card 2.6 DigiDesign SampleCellII Plus PCI TDM daughter card 2.7 DigiDesign SampleCellII PCI No TDM daughter card 2.8 empty 2.9 empty 2.10 empty Second half of both of the the expansion chassis(s) are missing?
NotoriouSS Tad PT 2023 HDX3 maxed system 7,1 Rack Mac Pro PT 5.1.3 OS9 maxed system G4 1.33 Last edited by ProTools4; 08-10-2008 at 08:09 PM. Reason: update!! |
I have extra parts to test wih now
2x 13 slot chassis 3x interface cards 3x i/o cables!!! all cards pass digitest solo.,,,, WTF?!
NotoriouSS Tad PT 2023 HDX3 maxed system 7,1 Rack Mac Pro PT 5.1.3 OS9 maxed system G4 1.33 |
I would try pulling that DSP Farm I and see what happens.
It may pass in DigiTest, but may still have something wrong causing data to not xfer to further cards. Do you know which revision that DSP Farm I card is? |
Assuming everything is rev QC or later, Put the DSP farm first, put your DSP farm II's after it.
My system: Mix core DSP farm DSP farm DSP farm DSP farm DSP farm II Samplecell TDM Samplecell TDM Samplecell TDM Samplecell TDM Works like a charm. Except of course in OSX I lose the samplecells, they simply don't show up. I wish digi would open source the samplecell software so someone could try to make it work with 6.4.1. Those cards were great. Other thing you might want to check is the power supply. Some of those exp chassis are underpowered. Mine has a 400W Antec, I think they came with 350 or 300 Watt. With 10 cards, that's pushing it. |
One other thing, the 13 slot chassis is split into two separate busses, I believe the first 7 slots and the last 6. A damaged cable from your host card to the chassis, or improperly seated cards could also be a culprit.
The split was so you could stick a PT rig and an avid system on the same rig, without them interfering with each other. |
I wil try all 3 calbes I have!
then I will ommit the DSP farms and try again
problem solved,
Drove down to Santa Monica and picked up a whole new Expansion Chassis
Digidesign Expansion|HD Expansion Chassis work ok? | Will Russell | Pro Tools TDM Systems (Mac) | 8 | 05-25-2006 02:19 PM |
magma one slot half length chassis | beardeddubster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-09-2001 03:22 AM |
magma one slot half length chassis | beardeddubster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-09-2001 03:16 AM |
HALF LENGTH ONE SLOT MAGMA CHASSIS | MidiMidiBangBang | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-07-2001 12:26 AM |
half dead 1622:no audio output | Vaphoron | Pro Tools TDM Systems (Mac) | 2 | 05-03-2001 07:41 AM |
