Old 08-10-2008, 01:01 PM
ProTools4's Avatar
ProTools4 ProTools4 is offline
Default **13 node cable** How big can a PT5.1 TDM go?
-What is the biggest PT Mix system you have seen or worked on?
-Is there such thing as a 13 node cable?
-Can one system use two expansion chassis?
-How big can a PT5.1 mix plus system be expanded to?
NotoriouSS Tad
PT 2023 HDX3 maxed system 7,1 Rack Mac Pro
PT 5.1.3 OS9 maxed system G4 1.33
Old 08-10-2008, 01:29 PM
digidesigner digidesigner is offline
Default
there can be 7 mix farms(or core cards) + 3 dsp farms max. there is an 10 node cable for that.
Old 08-10-2008, 01:39 PM
ProTools4's Avatar
Default
digidesigner
Are you saying it will only suppoert 7 mix cards? Why?
What if you want more?
What if I made my own custom 13 node cable?
NotoriouSS Tad
Old 08-10-2008, 01:59 PM
Shawn Simpson Shawn Simpson is offline
Default
Only 7 mix cards are supported in one system. You'd have to ask Digidesign why they did it that way. It's a similar situation in the current systems.
If you want more power, you'd need to go to a modern system.
You could make your own node cable, but you'd also have to rewrite some of the software code and probably change some hardware elements to make it work, so keep us posted on how that's working out for you.
Old 08-10-2008, 02:14 PM
ProTools4's Avatar
Default
well I'm not into that kind of investment.
I'll just purchase 3 more Mix Farms and get back to making music.
NotoriouSS Tad
Old 08-10-2008, 05:53 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default
I have a Mix core + 5 DSP farms and 4 samplecell TDM's with the 10 node cable. The limitation I usually run into is usually not DSP, it's using up track count or TDM time slots.
Both of these limitations have been addressed with HD, but can also be addressed other ways...
You could build two systems, each with 7 mix cards, lock them with word clock and send SMPTE from one to the other. Uh, yeah... 14 mix cards. That'll double your track count too.
Old 08-10-2008, 05:55 PM
Default
I think you might also run into PCI bus bandwidth issues with 13 cards, that might be the reason for the 7 card limit.
Old 08-10-2008, 08:05 PM
ProTools4's Avatar
Default
that would make sense
how much data can you push thru the PCI buss and extender I/O card
there has to be a limit some were
right now I'm having trouble gtting the 2nd half of my expansion chassis on line.
I have for testing 2x 13 slot chassis 3x interface cards 3x i/o cables!!!
still cant bet the second bank of cards online...
WTF?!
NotoriouSS Tad
Old 08-11-2008, 04:44 PM
tech_head tech_head is offline
Default RE: **13 node cable** How big can a PT5.1 TDM go?
It has to do with the number of TDM Slots available *AND* how many cards you can drive on the bus.
So one limitation is time slots, you only have 250.
The other is the ability to drive the cable and have the I/O turn around in time so you do not have multiple drivers on the TDM bus.
TDM (not HD TDM) is a single broadcast multi-listener bus.
The new implementation is point to point between cards.
node cable bertje General Discussion 1 08-18-2004 03:18 PM
Node cable???? max the mac Digidesign Hardware & Software 1 03-19-2003 11:39 AM
Bit 3 - 13 slot chassis w/ 11 node cable. Skip 4th node? ProTooler Pro Tools TDM Systems (Mac) 2 10-31-2002 09:31 AM
3x 5-node Ribbon cables = 12-node cable? UTS Pro Tools TDM Systems (Mac) 1 03-19-2002 11:57 PM
Really an 8 node TDM cable trombino Pro Tools TDM Systems (Mac) 3 07-25-2001 06:21 AM
