DigiTest Nor PT Will Run
I need a little help.
I'm running a 2 GHz G5 Dual Core Mac with 2GB RAM OS 10.4.8 Separate internal audio HD 23" Mac monitor Pro Tools HD 2 Accel MassivePack Pro 4 Digidesign PRE (2) 192 I/Os w/192AD Expansion cards Magma PE6R4 6 Slot PCIe to PCI-X Expansion Chassis Host Card installed in slot 4 installed Pro Tools HD 7.1 from disc. I believe I installed all the hardware correctly but I can't run DigiTest as I keep getting an error message that states "Cannot run DigiTest because another application is already using the Digidesign hardware..." I shut down and restarted being mindful of the order starting with the Chassis, the I/Os then the computer and I still get the error. I double checked via the finder that the pci bridge is in place and it also shows two listings for "Other Bridge Device" which I suspect is the two FlexCables connecting the cards. I even tried booting Pro Tools and it wouldn't boot stating that another application was using the hardware. The only thing running is the OS so I'm stumped. Anybody have any ideas what might be causing this?
2 GHz G5 Dual Core Mac with 2GB RAM OS 10.4.8 Pro Tools 7.3.1cs8 Separate internal audio drive 23" Mac monitor Pro Tools HD 3 Accel (PCI 1 Core Card, 2 Accel Cards) MassivePack Pro 4 Digidesign PRE (2) 192 I/Os w/192AD Expansion cards Magma PE6R4 6 Slot PCIe to PCI-X Expansion Chassis |
Re: DigiTest Nor PT Will Run
Where can I get Digitest? | heybluez | Pro Tools TDM Systems (Mac) | 2 | 05-13-2007 12:16 PM |
digitest on g5 | mixer | Pro Tools TDM Systems (Mac) | 0 | 01-20-2004 06:37 AM |
Digitest | bounce88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-09-2002 08:56 AM |
Digitest | Jim Roberts | Pro Tools TDM Systems (Mac) | 2 | 02-11-2000 01:18 PM |
Bug in DigiTest 2.5.1a1 | Oliver M | General Discussion | 0 | 06-23-1998 08:00 AM |
