Old 01-06-2011, 11:02 AM
Raoul23 Raoul23 is offline
Question PT 9.0.1 and 003+ drivers
Hi
if i do a fresh clean install of PT 9.0.1 from unistalling 9.0.0 do i have to reinstall the separate drivers for the 003+ like i did when i first installed 9.0.0
Regards
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-06-2011, 12:37 PM
Default Re: PT 9.0.1 and 003+ drivers
Just installed 9.0.1 and installed the same 003+ driver which I had when I downloaded 9.0.0 and now I get the message cannot locate hardware does anyone no if I have to get different drivers
Please someone help I'm so frustrated
Regards
Raoul Crane
Old 01-06-2011, 03:09 PM
nainesh nainesh is offline
I'm getting the same error on my 002r. Any suggestions?
Old 01-06-2011, 03:23 PM
Sorry...
...reinstalled and now it's seen. Still having problems with midi however (see other post)
Old 01-07-2011, 01:26 PM
TOM@METRO's Avatar
Regards
What driver version is showing in Device Manager?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-07-2011, 01:35 PM
mykhal c's Avatar
mykhal c mykhal c is offline
Regards
but the 9.0.1 download directs one to download drivers associated with that update. now i don't know if the versions are different but one should definitely download the drivers as directed and NOT use the ones from 9.0.
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 01-07-2011, 05:07 PM
Ive uninstalled 9.0.1 and reinstalled 9.0.0 and it's all working don't think I'm gonna do the update at the mo. The only prob I'm getting is when I close pro tools then try to open it again it gives me the message pro tools did not shut down correctly last time you need to restart your computer which is abit of a pain
regards
Raoul Crane
Old 01-07-2011, 07:21 PM
George Ware George Ware is offline
In PT-9.0.1 I get the same error no audio device found. but Acid 7, Sound Forge 10 and Vegas are using my 002 rack.
It worked fine in 9.0
Old 01-08-2011, 04:06 AM
bootybandit bootybandit is offline
This might help:
http://duc.avid.com/showthread.php?t=291660
Healing the world through music.................
Sony Vaio Laptop|2 Core P8700 2.53 Ghz 8 Gb Ram|Win8 x64
PT 9.0.6|Cubase 7|Samplitude Pro X|Reason 5|Spectrasonics|Komplete
RME BabyFace|AxiomPro49|Akai LPD8
Old 01-08-2011, 05:23 AM
Now working,
Turn off 002 rack.
Uninstalled PT 9.0.1.
Uninstalled Avid 002 & 003 rack drivers v9.0.
Ran RegVac.
Checked Acid to see if Digi HW was gone.....yes.
reboot system.
Installed (full version) PT 9.0.1.
Installed Avid 002 & 003 rack drivers v9.0.
Turned on 002 rack.
Checked PT worked
Checked Acid 7 worked as Classic Wave Drivers only
Checked Sound Forge 10 worked as Classic Wave Drivers only
Checked Mini Moog V worked as ASIO.
Hope this helps
003 Drivers tmitchell Pro Tools 10 6 10-27-2013 03:24 PM
Drivers MandoDjango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-19-2009 10:51 AM
Drivers sykobilly65 Pro Tools M-Powered (Win) 4 09-23-2005 06:18 PM
HUI drivers.... edytnbch Pro Tools TDM Systems (Mac) 1 04-12-2005 04:14 PM
OSX drivers or proprietary PT6 drivers-what will it be? pfd4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-02-2003 02:04 PM
