Old 07-23-2007, 04:18 AM
turing turing is offline
Default serious tdm problem
i'm running a carillon 2.4ghz p4, 1.5g ram, and 6.4 tdm mix3.
whenever i get to a certain track/plug in count (and it's never huge, usually somewhere around 30 tracks or so), something really freaky happens to anything going out of outputs 1-2.
the audio itself in unaffected, the fader position is nominally the same, but suddenly it's like the bus has reset itself and everything is deafeningly loud from those outputs.
it happened again the other day, when i just finished a mix, and made a new stereo track to print it onto, and suddenly my levels were shagged.
i've removed all other drivers - asio, wavedriver etc, and reinstalled pro tools, but no luck.
could anyone help me on this before i drop kick my pc out the window and buy a mac.
many thanks
Old 07-23-2007, 11:32 AM
MDog MDog is offline
Default Re: serious tdm problem
Are you feeding your mix back in to the session? If so, are you muting the master track as you record? I prefer "Bounce to Disk", it skips a generation by going straight to a file. I can also create an interleaved stereo file instead of having to combine them later (avoiding another generation of data manipulation). Good luck
My best friend is a pitbull.
http://www.badrap.org
Old 07-23-2007, 02:21 PM
i record it back cause i'm using the neve summing mixer and lots of outboard stuff patched around, and the bounce to disk function only covers outputs 1-2.
but it's not simply when i'm bouncing a mix that the problem crops up.......that's just the most annoying scenario. it's whenever the track count or plug in count reaches a certain, as yet undefined point that the bussing go weird.
anyone got any ideas? it's really getting me down.
Old 07-29-2007, 07:02 AM
George Ware George Ware is offline
What version of TDM Mix are you running?
You should be on 6.4.1CS4
I saw this on some other version of 6.4.1.
But mine is ROCK solid 64 tracks, putting along on a old P4 1.7Ghz with WinXP Pro SP1!
George Ware
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? Priz Windows 1 09-25-2011 12:51 PM
ELS Vocoder plugin problem and fresh Windows 7 install problem Thorpey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-09-2011 05:03 AM
Repeatable problem MP 7.4 upgraded to 8, ProFire 2626 problem tylerparkinson Pro Tools M-Powered (Mac) 0 08-21-2009 02:20 PM
digi 002/7.4 installation problem/not recordable volume problem fifthflaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2008 01:28 PM
Audio Regions Display Problem & Grabber Problem markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-25-2002 04:08 AM
