Old 04-04-2022, 12:23 PM
Eric Lambert's Avatar
Default Using an HD Native Thunderbolt w/ the new Macs??
These HD Native Thunderbolt boxes are Thunderbolt 2 and use the TB2 connector (I suppose some call it mini displayport). The new Macs have USB-C ports. You can see where this is going...
I'd initially thought that I could use Apple's basic TB2-to-USB-C adapter, but I noticed in the fine print that this adapter doesn't work with certain displays, namely those with Displayports. This got me wondering if this adapter would work with the Avid HD Native Thunderbolt box.
Does anyone know? Cutting to the chase, what is the absolute best option for connecting TB2 to USB-C? It's the MacStudio Ultimate that I have in mind, if that helps. They do have a different type of connector on the front, if that weights into the equation.
This is the adapter in question: https://www.apple.com/shop/product/M...duct-MMEL2AM/A
Old 04-04-2022, 01:15 PM
Default Re: Using an HD Native Thunderbolt w/ the new Macs??
It should work fine, PCIe over Thunderbolt foo is relatively simple. Many many people here use these Apple Thunderbolt 3 to 2 adapters with the Thunderbolt Native box.
The display warning you are worrying about is not relevant here. Thunderbolt 1 and 2 used a Displayport connector instead of the USB-C connector used in Thunderbolt 3 and 4. All the warning is pointing out is even though the connector look the same you can't plug this Thunderbolt adapter into an actual Displayport port and expect it to work. And what is going on with display over Thunderbolt is different to PCIe data over Thunderbolt.
But note that one user on DUC reporting having problems with Native on a Mac Studio with a Lynx interface (which may or may not be relevant) on the Mac Studio, not clear of the cause: https://duc.avid.com/showthread.php?t=419428 another user in that same thread reporting Native runs fine. And we are maybe getting off track there with HD native PCIe vs. HD Native thunderbolt.
Old 04-04-2022, 02:22 PM
Fantastic. Thx Darryl!
Old 08-27-2022, 07:38 AM
iode131 iode131 is offline
I find myself in a similar conundrum.
I just got a Thunderbolt HD Native to use with a new M1 mac mini. Got the same recommended USB-C-to-TB2 adapter from Apple and performed all the required setup steps, including the Security ones. I'm confident all is well on the software side.
But the box will not turn on. Dead. No power led, no show in PT, no show in MacOS System Report.
My question is: I got a Mini DisplayPort cable in the box, not a Thunderbolt cable. Could that be the issue?
Thanks
Old 08-27-2022, 09:21 AM
M1 needs native drivers. You need to wait until PT is Apple Silicon native software w/drivers.
Old 08-27-2022, 09:30 AM
What? No.
Avid has had Apple Silicon HD Driver support available for some time. This does not require all the Pro Tools application software to be Apple silicon native, just the HD Driver.... which was done a while ago... how do you think all the other users talking about running HD Native and HDX with Apple Silicon systems get their stuff to work?
Old 08-27-2022, 11:23 AM
I don't think all of the users, but my HDN is not good to go with Apple Silicon
Old 08-28-2022, 10:42 AM
Quick 2 cents:
Using a proper Thunderbolt cable (not the miniDisplayPort cable that was included in the box) solved all my issues.
My HDN connects fine, gets all the power it needs and I can confirm that PT Ultimate works as it should on M1 with the latest HD drivers (as of Aug28 '22) and MacOS Monterey 12.5.1
Old 08-30-2022, 03:47 AM
chaos audio chaos audio is offline
He is talking about a HD Nativ Thunderbolt Box. This works without any problems. HD Native PCIe cards do not work so far (with M1 Mac Studio).
PT Ultimate 2023.6, HD NATIV PCIe,
MacStudio Max, Sonnet EchoIIID, MTRX Studio, 2x192, UAD2 Quad, Sonnet Fusion SSD Raid, Dolby Atmos 7.1.4,
Mac OS 13.1.
Old 08-30-2022, 05:04 AM
Yes, indeed. Darryl Ramm tested this on another thread nand I ate my hat. Nothing beatsm good testing.
Thunderbolt via HD Native box vs. Strictly Thunderbolt TheGrobinson Pro Tools HDX & HD Native Systems (Mac) 3 09-29-2022 04:30 AM
Avid HD Native Thunderbolt and Thunderbolt Cables. SoundEng1 Buy & Sell 0 10-30-2018 10:24 PM
HD native thunderbolt with thunderbolt card on desktop PC? martthie_08 Pro Tools HDX & HD Native Systems (Win) 9 10-12-2016 10:26 PM
HD native thunderbolt through Echo Express SE Thunderbolt Chassis hkj1 Pro Tools HDX & HD Native Systems (Mac) 1 11-06-2013 05:49 PM
Firewire interfaces with thunderbolt only macs John_Toolbox Third Party Interfaces 10 09-27-2013 11:43 AM
