Old 04-26-2010, 01:13 PM
Newpostguy Newpostguy is offline
Default BM Intensity pro woes
Been running the intensity pro for a few months now.
Last day on a mix, got in and no video. The "video out PCIe" option in PT is gone. BM settings in system preferences are preyed out. Popped the box open, swapped PCIe slots (luckily had a spare) and it seems to be working.
I dont like this at all. Granted the card is pretty cheap. I trusted this device and now question is reliability.
Thought I would share.
Old 04-26-2010, 01:16 PM
infiniteloop infiniteloop is offline
Default Re: BM Intensity pro woes
re-seating cards is kinda one of those things you sometimes have to do in PCI world. Did you seat it back in its original slot after that and see what happened?
Old 04-26-2010, 01:31 PM
Hmm maybe it is. The PCI world is not one I have spent much time in. I did not try the same slot again, since the client was here and mix needed to be finalized (taking a break atm), I just wanted to make it work so things didn't start looking bad in front of the money.
I suppose I should try the old slot later on otherwise I can't confirm the problem was with the BMI and not the slot itself.
Thanks loop.
Old 04-26-2010, 01:40 PM
could be dirty contacts, or inclement temperature, vibration or bad juju.
Old 04-26-2010, 03:46 PM
mikevarela mikevarela is offline
also, a newer version might have been released, check the updates page.
I've also had issues with mine...
any answers on why a DV movie would appear blue? I've played witht he output processing and output tabs in the BM apllication but nothing helps
TV is 720p, but works with 480p and 1080i
NuanceTone.com
HTML code is On
Why buy a BM Intensity Pro? jseelye02 Post - Surround - Video 27 07-25-2013 05:23 AM
Pt9.6 and intensity pro sven larsen macOS 0 08-28-2012 04:27 AM
BM Intensity Pro support, when? olamo Windows 4 08-09-2011 11:15 AM
Intensity Pro Problem Nathan W. Post - Surround - Video 5 06-02-2011 10:43 AM
Intensity Pro EarHole Post - Surround - Video 16 04-28-2011 08:49 AM
