Old 04-02-2010, 07:50 AM
kd_special kd_special is offline
Default Laying back to SONYHDSR Deck
Does anyone layback from pro tools to a a Sony HDSR Deck. Using AES? Im just curious becasue the SYNC I/O doesn't support Tri Sync. So how do I get PT to lock to the Deck.
So do I just set PT to chase the Deck at 23.98 and hope it stays in sync? these shows are 1 hour long. I would love to be able to to strip these myself from the studio. Its nerve wracking to leave my restripe up to a online video editor, they barely even listen to the audio on thier final pass.
And its my ass on the line.
Anyone do this regularly?
kd
Old 04-02-2010, 07:52 AM
infiniteloop infiniteloop is offline
Default Re: Laying back to SONYHDSR Deck
you're going to need to give us more information. What frame rates are running?
Old 04-02-2010, 10:39 AM
hummerZ hummerZ is offline
Just run an AES line out of the HDCAM into Pro Tools and clock from that. And yes, you'll be able to lock up at 23.98 with no problems. I do it all the time.
You should also be able to clock from the SD video reference on the sync i/o and be OK, but only if the HD & SD house references are synchronized.
Old 04-02-2010, 11:49 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
HDSR for broaddcast is usually 1080i 29.97DF.
Run NTSC blackburst to your Protools, and the HDSR reference in.
Do a search for HDSR layback. There are some menu options you need to be aware of, like the 4 frame offset, and using LTC, not Serial TC.
IMDB
Old 04-02-2010, 02:22 PM
We have house Ref but that is only at 29.97 black burst (everone is locked to that). However the video side and their decks have their own reference I was told it is Tri-Sync and they use that sync for these particular masters.
I really don't want to run an AES line to the PT rigs. (Do you mean run an AES to the SYNC I/O? I'm pretty sure I could do that. I record in from that deck all the time AES. But not to code or anything.
thanks in advance.
kd
Old 04-02-2010, 02:24 PM
My PT session is 23.98 and the master tape is 23.98.
thanks
kd
Old 04-02-2010, 03:08 PM
As long as you are locking up OK to LTC and resolving your word clock to a reference derived from the same source as the deck (or the deck itself), you'll be fine.
So yes, you could clock pro tools via an AES return from the deck, input to either your sync i/o or 192.
In this scenario, you are effectively resolving to the house tri sync... it's just that instead of a sync HD, you're using a $75k deck to derive your word clock from HD sync!
ya dig?
Old 04-02-2010, 09:22 PM
Cool I think I got it.
In the quote above do you mean a digi SYNC HD vs a digi SYNC I/O? I can get my hands on a SYNC HD. I can just swap one from another studio. Would this be a better sync box. When i physically look at them I could not tell the difference between the 2 models. And didn't see any extra info int he box. Am I wrong?
kd
Old 04-02-2010, 10:26 PM
Chief Technician Chief Technician is offline
Thumbs up Re: Laying back to SONYHDSR Deck
Great.
Do it.
Yes.
The logo on the left side is different. On the SYNC I/O it says SYNC. On the SYNC|HD, the size of SYNC is different, and it says HD underneath SYNC.
The SD/HD designations for the video ref LED don't exist on the SYNC I/O.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 04-03-2010, 09:43 AM
What show are you doing??
As I stated above, most networks that broadcast in HD, have 10801 299.97 delivery requirements. I do shows for Bravo, NBC, and Showtime.
IMDB
HTML code is On
Laying to DIGIBETA deck with 002 or 003 senorsensor Post - Surround - Video 14 09-07-2010 03:58 PM
Laying back to Tape Peter Groom Pro Tools TDM Systems (Mac) 0 02-08-2007 06:34 AM
delay / latency when laying back audio to D5 deck epm Post - Surround - Video 2 01-30-2007 05:46 PM
Laying back to HDW F-500 bryston Post - Surround - Video 12 01-08-2007 12:13 PM
Laying Back to Digibeta? HiRaX Post - Surround - Video 11 01-06-2006 07:41 AM
