Old 01-05-2020, 10:48 AM
secutanudu secutanudu is offline
Default "Online" Mode?
This happens to me ALL the time, and I cannot figure out why. I go to record or turn the click ON, and I get a message telling me that I can't go into "countoff mode when online". It also does not let me record while this button is lit up.
I have no idea what I'm doing to accidentally turn this on. I also have no idea what it's for.
I have to click this button to turn it off before I can either record or turn the click on.
Any idea what this is and what I am doing to constantly turn it on by accident? Thanks!
Old 01-05-2020, 11:15 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: "Online" Mode?
Turn it off if you are not syncing to external clock
Janne
Old 01-05-2020, 11:53 AM
BScout BScout is offline
The shortcut is Control+J or Alt+Spacebar to turn on/off online mode. My guess is you are using Control+Spacebar for record but accidentally hitting Alt+Spacebar (much harder to accidentally hit Control+J)
Online mode is for syncing to other systems via MTC or MMC or LTC/VITC (if you have a Sync HD.) It puts Pro Tools in a wait state for incoming timecode or commands for the transport. We use it to sync Pro Tools to other DAWs (like Logic or Cubase.) On a system with a Sync HD, it uses that to lock to other systems.
It used to be also the way to sync two Pro Tools system before Satellite became a thing so now it is mainly used to lock Pro Tools to other DAWs (since they can't do Satellite)
It has nothing to do with with external clock unless the clock in reference is positional timecode. External clock usually refers to word clock/sample clock/house clock.
Old 01-05-2020, 11:58 AM
JFreak's Avatar
Thank you for clarification. I was just saving my fingers
Janne
Old 01-05-2020, 01:20 PM
Hmm - I do use CTRL+Spacebar to record sometimes - but I can't imagine I accidentally hit ALT+Spacebar that often. This happens a LOT to me.
That being said, I have no other explanation either. At least I know I can shut this function off with ALT+Space.
Thank you!
Old 01-05-2020, 02:06 PM
DontLetMeDrown DontLetMeDrown is offline
I get this a lot since I use Ctrl+K to turn on/off the pre-roll, and sometimes I'll accidentally hit J.
Error: "Pro Tools cannot be put online while in loop play or loop record mode." msg6794 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-12-2016 06:09 AM
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
"waiting for note" or "online" DMiddlezz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-19-2010 11:31 AM
Switching subwoofer from "discrete mode" to "stereo mode"? Slerker Post - Surround - Video 6 02-11-2009 07:04 PM
What's the difference between "online" and "offline" editing ? stuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-21-2002 03:46 PM
