Old 06-03-2013, 06:22 AM
gafyn gafyn is offline
Default Importing audio without copying?
Is there a way of importing / streaming audio in to the Pro tools project without copying them in to the audio folder?
I have WAVs from a live event on a seperate hard drive, I would like to just use this to save space on my project hard drive and time with the copy.
Thanks guys
Gaf
There is no Spoon
Old 06-03-2013, 06:53 AM
robo6675 robo6675 is offline
Default Re: Importing audio without copying?
Assuming your session is at the same bit depth and sample rate as the audio file you want to use, while using the "import audio" function, select "add" instead of "copy". That way the audio shows up in the session but the audio file still lives only in its original location.
I caution you on this practice though. You'll always need to have that drive connected for the session to function properly. I usually play it safe and keep my sessions self contained, in one place.
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod
Terrarium
HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2
(3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console
Old 06-03-2013, 09:10 AM
Hi, Thanks for the reply.
Yes everything is of the same sample rate and bit depth.
I've just realised that it's the stereo tracks that convert and not the mono ones.
Everything is copied over in to one of my internal hard drives, I just didn't want them twice, thanks for the caution though.
So does my project file have to be in the same place as the audio files then? that is curently what I have done but I would prefere it not to be.
Thank you.
There is no Spoon
Old 06-03-2013, 10:53 AM
CME CME is offline
I'm assuming the stereo files are interleaved? If that's the case make sure you have interleaved selected in the session settings and it add those files instead of copying.
And you can keep the session file and audio files in different places. I do what you're talking about all the time, but keep the session file on the external drive with the audio files. You need both for the session to work, so you might as well keep them together. At least IMO.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 06-04-2013, 04:44 AM
Hi thanks for the reply,
I don't seem to have the option to select interleaved in my sessions settings, I am runing PT 8 - so this may probably be the reason.
Thank you very much
Gaf
There is no Spoon
Old 06-04-2013, 07:56 AM
CME CME is offline
Sorry. That isn't an option in 8. Don't remember if it was first available in 9 or 10. But somewhere along the way we've been given that option.
Old 07-02-2013, 03:36 PM
solidwalnut's Avatar
solidwalnut solidwalnut is offline
You can always just 'drag and drop'. This is a shortcut which will import the audio and convert it to the parameters of the session.
Steve
Worship Leader * Producer * Guitar Man
Intel i7 3930k CPU, Gigabyte GA-X79-UD3 MB, G.Skill 16GB (DDR3 1600) RAM, WD Caviar Black 750GB HD x4
Neve 5043 Comp * Manley Dual Mic Pre * Apogee Rosetta 200
Eleven Rack (live rig and studio rig!!)
Win7 * 003R * PT 11
Old 07-02-2013, 05:23 PM
You can UNcheck the boxes(in Preferences) for automatically copy files on import. Do what make the most sense for you. As for me, I would rather have 6 copies of the audio instead of archiving and discovering months later that some audio is not where I thought it was(or maybe not found at all). Once bitten.......
Import Audio Is Not Copying Files To My Audio Folder zwatrif Windows 12 11-14-2017 09:32 PM
Copying Audio PihSant General Discussion 7 11-09-2009 09:44 PM
Copying Audio regions issue djdp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-09-2005 07:33 AM
Duplicating/copying audio to grid Luke Annett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-19-2005 08:42 PM
Importing playlists in 6.1 w/o copying audio files Blossi Pro Tools TDM Systems (Mac) 7 11-23-2003 09:26 AM
