Old 02-03-2003, 06:30 PM
putney2 putney2 is offline
Default Re: Format for Bounce To Disk, if mixing in WAV?
AIFF or SDII
As I understand it the file types use different headers. No loss of data.
Might be wrong.
Old 02-04-2003, 12:21 AM
el biciclista el biciclista is offline
Default Format for Bounce To Disk, if mixing in WAV?
I am using the WAV format in ProTools 5.3 (rather than SD II), since this is the default format for HD. However, Toast can't handle this format. So, what format should I use when Bouncing to Disk, in preparation for burning a CD?
Does bouncing to disk in a different format create any loss-of-data problems because of the conversion? [img]images/icons/confused.gif[/img]
Thanks,
Mike
Old 02-04-2003, 10:33 AM
mike connelly mike connelly is offline
I'd use aiff since it's also windoze compatible.
All three formats are the same data, it's just stored differently and different headers.
Now why can't toast add support for burning .wavs???
How to bounce mp3 format to disk? tommykoot Pro Tools M-Powered (Win) 6 11-05-2010 05:13 AM
How do I "bounce to disk" to CD audio format? BRB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-24-2006 07:50 PM
bounce to disk what format should i use to listen lenno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-26-2004 05:58 PM
Can't Bounce to disk in Mp3 format.... Gwanillium 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-16-2004 08:54 AM
Session in WAV format; bounce to disk in SD II?? el biciclista Pro Tools TDM Systems (Mac) 2 02-05-2003 12:56 AM
