How to bounce mp3 format to disk?
I just tried to bounce some tracks to my disk in mp3 format. Pro Tools says that the MP3 can not be enabled because: Module initialization failed for MP3.dll. The MP3 demo period may have expired. Any way to fix this? How can I get my audio files on a cd if this occurs? Thanks again!! Tommy |
Re: How to bounce mp3 format to disk?
Hi Tommy,
Mp3 output needs to be purchased separately. Either you buy the option or you bounce as wav to disk and convert it after bouncing with a mp3 converter. On mac I use Swiitch and on windows a program called Super. Both are doing the job. Hth, Bow |
If I need an MP3 file I bounce a .wav or .aif and then convert to MP3 using iTunes. But you asked how you would get your audio files on a CD if you cannot bounce MP3 files, which make me wonder - what kind of CD are you creating?
If you are making a standard audio CD then you shouldn't use MP3 files at all! You should bounce 16 bit/44.1khz .wav or .aif files and use those to create your CD. Otherwise you are converting to MP3 and losing quality for no reason. |
search...
Module initialization failed for MP3.dll at avid.com gives me this... http://www.avid.com/US/search?q=Modu...P3.dll&x=0&y=0 |
Load your wav file in Audacity and export as MP3. Free and easy. You'll need to download the free Lame codec.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
Trikome.com - blog PTMP 8.0.1 // FLStudio 9 // WinXP SP3 // Axiom Pro 49 // Delta 44 // Mackie HR624 // AKG K701 // Emu 6400 Classic |
Can't Bounce the track to disk using an MP3 format | Rybo15 | Pro Tools M-Powered (Win) | 2 | 03-27-2008 07:07 PM |
How do I "bounce to disk" to CD audio format? | BRB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-24-2006 07:50 PM |
bounce to disk what format should i use to listen | lenno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-26-2004 05:58 PM |
Can't Bounce to disk in Mp3 format.... | Gwanillium | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-16-2004 08:54 AM |
Format for Bounce To Disk, if mixing in WAV? | putney2 | Pro Tools TDM Systems (Mac) | 2 | 02-04-2003 10:33 AM |
