No click coming out of click track
Hey hey
So I'm in a bit of a situation. I put a click down on an aux in, as per usual. But lately there has been no 'click' from the plugin. I figure it's got something to do with my MBox2 and MIDI, but not quite sure what it is... Can anyone point me in the right direction? Cheers, Rob. |
Re: No click coming out of click track
Do you see something happening on the aux track and just don't hear it?
If yes: - Is the aux track's output routed to the outs you are listening to? If not, try to check: - did you select a preset in the click plugin? - is the click switched on in the transport window? - is it set to click during record only? Or playback? Or both?
MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire |
I usually just go up top and click on track and at the bottom of the list there is Click, I load that and am good to go, I've Never put a click on an Aux track.
Stay true to the sound,Less is best |
Make sure click is enabled on the transport
Yeah Numeric Keypad 7 enables the Metronome Click however if you are running Pro Tools 8 and above the Edit Window Customizable Toolbar does not display the MIDI Controls - Metronome button by default and to add to the confusion the Metronome button is also disabled. A little silly IMO.
filosofem |
Try putting the click on an audio track instead of aux, see if it makes a difference.
www.myspace.com/solstate |
Avid can you please sort out the click track & Click 2 plugin | protoolsuserman | Pro Tools 11 | 14 | 11-14-2013 08:11 AM |
No click sound on click track | sighermike | Pro Tools M-Powered (Mac) | 3 | 10-10-2012 12:01 PM |
Getting the click track to click at 16th notes... | broken81 | Tips & Tricks | 1 | 06-27-2008 07:06 PM |
Click Track No Click | CTT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-20-2008 01:16 PM |
Click Track - How to "UN" accent the click plugin | pepperbox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-02-2006 06:37 AM |
