Old 09-23-2010, 07:01 PM
nst7 nst7 is offline
Default Re: Oxygen vs Axiom (buy help)
M-Audio just came out with the Oxygen 88. It's got 88 weighted keys and the new "Direct Link".
Check it out:
http://www.m-audio.com/index.php?do=...3858c234786746
However, the cost is $599 (Sweetwater has it listed already).
Old 09-24-2010, 12:16 AM
Julia B Julia B is offline
@ OP: yes i've used midi and the score editor, and it works quite well. And printed the score for tabbing. Or for reference. This is one feature i wish was available in Reason and some other VIs.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
Old 09-24-2010, 05:49 AM
play4theworld play4theworld is offline
I was looking at that keyboard, It's cheaper than I would have thought but I defiantly don't want to spend $500 right now and I don't know where I'd put another 88 keys.
Oxygen 88 Alexander4444 MIDI 1 10-07-2012 12:58 PM
Axiom Pro 49 and Axiom 61, Prepheral issue? udhoshi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-22-2011 03:45 PM
Anyone here with a PC and Oxygen 8 AubreyT MIDI 0 06-30-2006 11:11 AM
oxygen 8 Edson MIDI 4 10-02-2005 10:33 PM
Oxygen 8 with G4 867 Christoph1123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-29-2002 07:45 PM
