Re: Delay Compensation and Recording
Just goes to show how efficient the Massey plugs are, compared to waves which has over 80 ms of delay as opposed to the massey's 1.4 ms (24/48) sb |
What happens to me is that I'll be playing a new MIDI part and when I'm done all of the MIDI notes are early in PT (OK, I'm not the tightest player, but it's much more drastic than just that). The VI responds pretty well live - not much of a player's delay - but it's rendered inaccurately, at least inaccurate relative to where I was actually playing it while recording. Is this a different problem altogether? |
#16
You understand the issue well enough to know that the cause is something else, but not well enough to spend additional time explaining it?
#17
Is the midi in the right place on the grid? What version did you use when creating the session, or was it created elsewhere? Do you have "real time properties" activated? offsets? Have you changed your hardware buffer settings? (setup/playback engine...) Try lowering that... Then, (or before then) trash your midi preferences. (using the trash pref utility) AND.... make sure that you turn off ADC when recording. Try that. I have had this issue before and it has been one of , or a combination of, the above. Good luck, sb |
PT 10 and Delay Compensation while recording | tekis | Pro Tools 10 | 7 | 03-10-2014 07:09 PM |
delay compensation during recording? | stevenson84 | Pro Tools TDM Systems (Mac) | 1 | 06-07-2011 03:35 PM |
Recording and delay compensation | Paolino_o | Pro Tools TDM Systems (Mac) | 2 | 04-13-2011 12:48 PM |
Recording With Delay Compensation On 2.0 | ryan de topanga | Pro Tools TDM Systems (Mac) | 26 | 01-19-2010 02:25 AM |
delay compensation during recording? | Ken P | Pro Tools TDM Systems (Mac) | 6 | 08-30-2006 01:06 PM |
