external effects with Digi 002?
Just wondering how I would connect an external stereo effects processer to the Digi 002 mixer to use in Pro Tools...I would assume there should be some type of 'aux send/return' input right?...
Also, can these external effect be used in real time as I am recording the track so the player can hear the effect with his instrument?..If it can, is there any latency?... Also, I understand that the 002 mixer has some effects built in, how are they?.... I don't own this mixer and have to do a job with it this week so ANY info suggestions would be VERY appreciated....thanks! |
Re: external effects with Digi 002?
It describes exactly how to do this in the Reference Manual. You use the inputs/outputs as sends/returns.
MacBook Pro Core Duo 1.83 2 Gig RAM OS X 10.4.8 002R/PTLE 7.3.1 |
ok, kewl, I figured it would use the inputs....
well, the only thing is that I do not own the mixer so I don't have the manual....is there anywhere on this site where the manual can be downloaded or looked at?....thanks again |
Tech Docs keep in mind that you must use the same inputs as outputs for external effects. i.e. - In 7-8 needs out 7-8.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
Latency can be as low as 64 samples depending on how much power your host system has. There is also a low latency monitoring mode you can check out. It has it's limitations, but worth checking out depending on how sensitive the artist is to latency. When are you planning to get your hands on the OO2? PTLE will take a little getting use to, although it is relatively intuative right out of the box. Getting a compatable host is usually more problamatic. Included plugin variety with PTLE is not that great. Basic EQ, Compression, Delay, and a gawd aweful reverb is bundled with the package.
MusicXPC 2.8/512 PTLE 6.4 CS6&9 Waves: Platinum(5) & IR1 (5.1) DigiOO2 Factory |
The "built-in" effects are only available in stand-alone mode so they won't help you. The SPDIF is a handy place to patch a digital effect unit like the TC M-ONE or anything with SPDIF I/O.
How do I connect external effects to a Digi-002R via S/PDIF? | AntManBee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-12-2013 04:20 PM |
external analog buss effects buss effects patching | bryanbassett | Pro Tools TDM Systems (Mac) | 10 | 10-07-2004 03:39 PM |
External Hardware effects VS plugin RTAS effects | boogiewoogie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-19-2003 06:25 PM |
Digi 002 w/external effects processor ? | moonmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-09-2002 09:41 PM |
DIGI 001 - External Digital Effects | Loran | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-26-2001 05:52 PM |
