Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 08-27-2021, 09:10 AM
Bob DiSilverio's Avatar
Bob DiSilverio Bob DiSilverio is offline
Default Running Pro Tools First - Getting Past Error 9178
I'm a would-be new user. Taking a recording technology class at school this semester. Downloaded Pro Tools First yesterday - Rev. 2021.7.0. - to see if I could get the jump on the instructor.
Can't get it to run. Software appears to be starting. Scans for plug-ins. Then returns AAE Error 9178 and quits. How do I get past this?
Bob
SiSoftware Sandra
ID
Host Name : DESKTOP-4O3BBAL
Workgroup : WORKGROUP
Computer
Model : HP Pavilion Gaming Desktop TG01-1xxx 103C_53311M HP Pavilion Desktop PC
Serial Number : 2MD10*****
Chassis : HP Desktop
Mainboard : HP 8767
Serial Number : PJJGE0H*******
BIOS : AMI (OEM) F.30 01/25/2021
TPM - Trusted Platform Module : Intel 2.0 2019 (24PCR 64Ses 7Obj 128Ctr)
Intel Management Engine (ME) : 14.0.45.1389
Total Memory : 31.88GB DIMM
Processors
Processor : Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz (8C 16T 4.7GHz, 4.3GHz IMC, 8x 256kB L2, 16MB L3)
Socket/Slot : FC LGA1200
Chipset
Memory Controller : HP PCI standard host CPU bridge 100MHz, 2x 16GB DIMM 3GHz 128-bit
Memory Module(s)
Memory Module : Samsung M378A2G43AB3-CWE 16GB DDR4 1Rx8 PC4-25600U DDR4-3200 (22-22-22-51 4-73-24-8)
Video System
Monitor/Panel : Samsung S24D590
(1920x1080, 23.5")
Video Adapter : NVIDIA GeForce GTX 1650 SUPER (1280S 10C SM6.5 1.53GHz/1.73GHz, 1MB L2, 3.9GB 12GHz 128-bit, PCIe 3.0 x16)
Graphics Processor
CUDA : NVIDIA GeForce GTX 1650 SUPER (1280S 20C SM7.5 1.53GHz/1.73GHz, 1MB L2, 4GB 11.5GHz/12GHz 128-bit)
OpenCL : NVIDIA GeForce GTX 1650 SUPER (1280S 20C SM1.2 1.53GHz/1.73GHz, 1MB L2, 4GB 11.5GHz/12GHz 128-bit)
D3D 11 : NVIDIA GeForce GTX 1650 SUPER (1280S 10C SM12.1 1.53GHz/1.73GHz, 1MB L2, 3.9GB 11.5GHz/12GHz 128-bit)
OpenGL : NVIDIA Corporation GeForce GTX 1650 SUPER/PCIe/SSE2 (4GB)
Storage Devices
Disk : PCIe SSD (1TB, PCIe3x4/NVMe)
Disk : TOSHIBA DT01ACA200 (2TB, SATA600, 3.5", 7200rpm)
Logical Storage Devices
WINDOWS (C:) : 953GB (NTFS, 4kB) @ PCIe SSD (1TB, PCIe3x4/NVMe)
Windows RE tools : 515MB (NTFS, 4kB) @ PCIe SSD (1TB, PCIe3x4/NVMe)
DATA (D:) : 2TB (NTFS, 4kB) @ TOSHIBA DT01ACA200 (2TB, SATA600, 3.5", 7200rpm)
SYSTEM : 256MB (FAT32, 4kB) @ PCIe SSD (1TB, PCIe3x4/NVMe)
Peripherals
LPC Hub Controller : HP H470 (Comet Lake) LPC Controller
LPC Hub Controller : T2 86-31
Audio Device : HP Core (Comet Lake) PCH cAVS
Audio Codec : Realtek Semi 0671
Audio Device : HP TU116 High Definition Audio Controller
Audio Codec : nVidia GeForce Go 7800 GTX
Disk Controller : HP Core (Comet Lake) PCH Shared SRAM
Disk Controller : HP Intel SD Host Controller
Disk Controller : HP ICH8R SATA RAID Controller
Disk Controller : Phison Electronics Corporation E12 NVMe Controller
USB Controller : HP Core (Comet Lake) USB 3.1 xHCI Host Controller
USB Controller : HP TU116 USB 3.1 Host Controller
SMBus/i2c Controller : Intel ICH SMBus
Printers and Faxes
Printer : Send to Microsoft OneNote 16 Driver (1200x1200, Colour)
Printer : Microsoft Software Printer Driver (300x300, Colour)
Printer : HP LJ300-400 color MFP M375-M475 PCL 6 (600x600, Colour)
Printer : HP LaserJet Mono PCLmS Class Driver (600x600)
Printer : Microsoft Print To PDF (600x600, Colour)
Printer : hpfax1 (300x300)
Scanners & Cameras
Scanner : Hewlett-Packard HP LJ300-400 M375-M475 Scan (Scanner, USB)
Biometrics
Voice : Analog NUI Voice Virtual Sensor (Voice)
Network Services
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Network Adapter : ExpressVPN TAP Adapter (Ethernet)
Network Adapter : Realtek Gaming GbE Family Controller (Ethernet)
Wireless Adapter : Intel(R) Wi-Fi 6 AX201 160MHz (Wifi5 (802.11ac/VHT), AES-CCMP, 780Mbps / 823.35Mbps)
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.19043
Platform Compliance : x64
Old 08-27-2021, 01:04 PM
Default Re: Running Pro Tools First - Getting Past Error 9178
Problem Solved:
I found C:/Program Files/Common Files/Avid/Audio/Plug Ins
I have been using other DAWs for a while and have collected some other plug-in that I used in other software.
How these populated in my Avid sub-directory is a mystery.
However, removing all of the plug-ins that predated my installation of Pro Tools First eliminated the problem. I just cut and pasted them to some other directory. Then ran the start up which threw a slightly daunting, but most welcome, editing screen up on the display.
Next stop: Understanding workflow.
Old 08-28-2021, 04:17 AM
Originally Posted by Bob DiSilverio View Post
Problem Solved:
Welcome to the world of ProTools and the DUC. Just take your time with the program and don't be afraid to ask questions here. Reading the manual is always a good first stop.
PT First only works with the plugins that come with it or that are purchased through the Avid store. So any third party plugins outside that sphere won't work. Just keep that in mind for the future.
Understanding workflow will take time. How you work will depend on what you're trying to do. Using vi's is a bit different than recording live audio for instance. If you've used other recording programs don't be surprised to see that PT doesn't do things just like another program. That can be maddening or liberating all depending on how you look at it.
BTW thanks for including the Sandra report. Big props on that. Something else that will help is if you put your system info on either your profile page or in your sig file. That way when you ask for help you don't have to retype things or waste time getting info to the people that can help. You'll see in my signature I have a hyperlink to my profile page with the system info.
Jack
QAPLA!
PT 2021.7 & AAE-9178 error dramis Pro Tools 14 08-21-2021 12:30 PM
AAE-9178 Error Patshill AAX Plug-ins 0 06-04-2018 02:30 AM
AAE Error -9178 JimGriffith Pro Tools 12 3 12-15-2017 05:50 AM
AAE Error -9178 JayRosa Windows 1 07-29-2017 01:28 PM
Pro Tools crashing after loading plugins AAE Error -9178 mremcbride Windows 3 12-07-2016 11:57 AM
