Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-05-2021, 03:54 AM
Talisker Talisker is offline
Default Re: PT on two screens
Same thing, actually...if I create a session from an old template from PT 10, it opens over two screens. If I create a session from scratch in PT 2020 spread it over two screens and then save it as a template, it comes back on one screen. So the question is still, where is that bit of information lost.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 01-05-2021, 08:39 AM
_JJ_ _JJ_ is offline
It's working as expected for me (PT 20.12 Big Sur) - create and save on two screens opens the next time on two screens.
Two thoughts, but pardon me if they're too obvious:
One is, when you drag the edit window to your external monitor, don't use the green "maximize" button fill the screeen. That puts that window into "full screen" mode and that pref may not stick for the next time. Instead, just drag the corners to the size you want or, (a trick I just learned) option-double-click on any corner of the window to expand it to the edges.
The other thing is to check System Prefs >> Security & Privacy >> Privacy tab, and make sure PT has "full disk access". I don't know where that specific pref is supposed to be stored but it sounds like PT is being denied the ability to write to that file...
Old 01-05-2021, 04:36 PM
huzzam huzzam is offline
You can also option-click the green button to maximize the window. Didn't know about the option-double click the corners trick though!
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 01-05-2021, 06:46 PM
paul_g's Avatar
paul_g paul_g is offline
Originally Posted by Talisker View Post
@ Paul G read the above maybe then you'll understand. I have no problem with old sessions I have a problem with sessions, I create now in 2020......got it ??
Dang... New sessions eh? Well, I can say I've created new sessions and they all open fine in two windows. Have you tried trashing prefs?
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 01-06-2021, 04:07 AM
Both monitors are the same size, so I just drag the edit window over to the other screen and never touch anything to resize it.
And Paul G I'm happy for you that you don't have the problem.....and yes I did trash the prefs.
  #16
Old 01-06-2021, 04:28 AM
midi sordino midi sordino is offline
Does the issue occur if you just save the session and re-open it, i.e. not as a template?
  #17
Old 01-06-2021, 04:44 AM
As I wrote above it occurrs in any case, no matter if I save it as a session or as a template. I was wondering if I maybe should do a full reinnstall of pro tools.
  #18
Old 01-06-2021, 09:55 AM
and ... PT has full disk access in your system prefs, right?
  #19
Old 01-06-2021, 03:44 PM
I have a similar issue since 2020.3, but it only happens after boot up. My issue is with video position on second monitor rather than edit or mix window. I have to recall using window config. Once I re-save the session it will recall windows correctly on both monitors. But if I boot up again it may or may not recall position.
I'm using an Apple Cinema Display as my second monitor and it's connected to an iMac Pro (and sometimes a MBP) using an OWC Thunderbolt 3 hub. I don't know if the hub is a contributing factor.
Does this issue happen every time you save a session? If you re-save a session after boot up, does it still not work?
PT 2020.5 on an iMac Pro with Mojave 10.14.6 & PT 2020.11 on a 2019 MBP with Catalina 10.15.7
  #20
Old 01-07-2021, 05:05 AM
@ JJ
Your're the man....I didn't give PT permission to control my computer...don't know how that happened since I'm sure that PT asked for it during installation but somehow I didn't . Now that I fixed that, it all works like it should....thanx a lo, mate.
When using two screens... Samba macOS 1 08-09-2020 08:16 PM
Using 2 Screens Rob2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-29-2009 08:19 AM
Is it possible to run 3 screens on a g5? Premo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-26-2008 03:24 PM
No Help Screens in 7.3.1 510man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-24-2007 11:29 PM
using 2 screens in PT - how do you do it? propofol Tips & Tricks 6 02-16-2007 09:33 PM
