Old 03-04-2001, 09:14 PM
kalasa kalasa is offline
Default Optical Cable
Can any one of you help me in knowing as What is the Maximum length of the Optical cable that we would be able to get
for connecting the ADAT Bridge with my Mixer.
Kalasa
Kalasa
Old 03-05-2001, 12:55 AM
IOP Drummer IOP Drummer is offline
Default Re: Optical Cable
Optical cables use light to transmit information. How far can you run it? What's the speed of light?? You can run them far. I would try to make the run as short as possible, but don't rearrange your gear around it.
Mike Blanchard
Engineer
Old 03-05-2001, 02:28 AM
I may want to run the cable for around 20 Meters. It is because my Adat Bridge is in my Equipment room and my Console is 20 meters away from it.
Is the Optical cable available in lengths more than 20 meters. What is the maximum length, that the Optical cables are coming in.
Kalasa
Kalasa
Old 03-05-2001, 09:19 AM
supersonic C supersonic C is offline
Anyone at Digi got any tech specs on lightpipe distance? This is actually not as simple as data going the speed of light, going down a glass tube. Thanks.
Old 03-05-2001, 06:45 PM
ppine ppine is offline
http://www.hosatech.com/OPT.html
and
http://www.macmidimusic.com/hosopcab.html
[This message has been edited by ppine (edited March 05, 2001).]
Old 03-06-2001, 07:04 PM
I also found out that Radio Shack, of all places, sells a Toslink inline amplifier..
Designed to push a signal to 60 or so feet, with sompin like 4.5db of gain, which is what would be lost at that distance, give or take....
Also they sell optical couplers, to extend optical cables...use at your own risk
Optical cable from my Mac Pro into my 192 I/O pmcmurt Pro Tools TDM Systems (Mac) 6 03-06-2009 03:16 AM
Optical cable Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-02-2007 11:46 AM
optical cable distortion x3rdretina 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-19-2007 12:25 PM
OPtical Cable Mic Pre roainfo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-15-2007 08:26 AM
ADAT Optical Cable Alagu Tips & Tricks 3 07-28-2001 08:52 AM
