How do I allocate more memory
How do I allocate more memory to protools and to dae?
Re: How do I allocate more memory
I have 1024 megs of ram, how can i allocate more memory to protools and dae. I know how to do this on my mac based tdm system, but i'm at a loss on my windows xp system, please help. thanks
As far as allocating, your computer allocates its memory with what you have open, so if you want the most of your resources going to Pro tools, then just don't have anything else running. Hit ctrl-alt-del, and go to the 'processes' tab, see what kinda stuff you have running, and how much memory it is taking up. Get rid of what you don't need. If you want to limit the amount of applications that become active on start up, go to start->run, and type msconfig. go to the startup tab, and get rid of the stuff you don't want to automatically start up when windows starts.. hope this helps. Tim |
Memory under Windows is a Shared Resource.. see this similar thread on the Mac forum which I answered.
Rail
This might help, however i can't remove my ram to have less. Also I can only run protools with the dae set to "0" this seems really odd to me.
DAE under Windows.. as it is under the Mac with v5.3.x and later.. is a DLL.. which uses the RAM allocated to the application using the Dynamic Link Library.
Rail
********************************************* Control panel> System> Advanced Tab> Click Settings in the Performance box, > Advanced Tab, > Memory Usage- click System cache. This reserves more memory for your application. |
Why Can't I allocate more memory? | AINSLIE | Pro Tools TDM Systems (Mac) | 12 | 01-03-2008 08:55 PM |
How does one "allocate more memory to DAE"? | Allbaldo | Pro Tools TDM Systems (Mac) | 5 | 09-26-2005 09:28 AM |
Memory is Low? Quit and Allocate more memory to PT | Unite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-08-2004 05:38 PM |
How to allocate memory? | Smakrabit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-17-2003 02:31 PM |
Help!! Allocate memory? | Craig Woolard | Pro Tools TDM Systems (Mac) | 1 | 03-26-2002 03:19 AM |
