Old 04-02-2003, 07:43 PM
jdavis74 jdavis74 is offline
Default Please help, no output / input from 001
This has never happened to me before. Basically, I'm getting no input or output from the 001 all of the sudden in PT LE 5.1.1 . Everything is connected, powered up, etc.
The system is a powermac g4 quicksilver 733 with 640 megs of ram and I have never had much of a problem before.
So let me give you a backround to where the problem began.
Had a problem with os 9.2.1, so I had to reinstall the system. I did not do a clean install, just the basic system folder and all was fine. Booted PT, fine, sound, input, everything.
Tonight I booted, and no sound, in or out. When playing back a session, the meters were moving, but nothing was coming out of my speakers. My poweramp and monitors are fine.
After that, I did a test session and I wasnt even getting and input!
So I reinstalled PT LE 5.1.1 and still nada. Please help friends, I know someone on this board has the answer to fix this.
Thanks
Old 04-02-2003, 08:29 PM
where02190 where02190 is offline
Default Re: Please help, no output / input from 001
Check your i/o assignments? Run the digi test?
Hope this is helpful.
Old 04-02-2003, 08:42 PM
Did both those things, nothing, no problems arise, but still no input or output.
Thanks for the reply, I appreciate it. This is really a mystery to me.
Old 04-03-2003, 07:18 AM
ah ha, and the simplest solution always does it. Unplugged the 001, plugged it back in, everything started to work again. Hehe, try to image the size of the foot in my mouth.
thanks
No active input/output Steisler macOS 7 03-14-2018 09:27 AM
MBox Pro 3G-no output/input Seth Thomas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 04:32 PM
EQ III input and output gain AdamPT8 Tips & Tricks 13 08-20-2010 02:23 PM
No Input or Output Signal AT ALL! CapitalJ001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-26-2006 02:30 PM
Input / Output Connections SpyAJ15 ICON & C|24 31 11-20-2004 01:19 AM
