Old 03-27-2021, 10:00 AM
scaramangaindustries scaramangaindustries is offline
Default Cannot navigate folders in Import Audio window by double-clicking them in 2021.3
I have noticed that I cannot navigate folders in the Import Audio window by double-clicking them. An inconvenience.
Last edited by jeffro; 03-30-2021 at 08:04 PM. Reason: Subject changed from "2021.3 new bug?"
Old 03-27-2021, 10:09 AM
Micks_Mix Micks_Mix is offline
Default Re: 2021.3 new bug?
Same here... hahaha, what's that?
I just tried to import some audio, but I can't navigate to my folders. Hot fix needed asap.
I am on Mojave.
Pro Tools|HDX Ultimate, 192 HD I/O, 192 HD Digital I/O, Focusrite OctoPre, Pro Tools 2021.3, Mac Pro 5.1, 24 GB RAM, Mojave
Old 03-27-2021, 10:13 AM
Originally Posted by Darryl Ramm View Post
Operating system? Version? You browsing local files on disk?
All works fine for me on Big Sur.
Mojave. 10.14.6. Native version of ProTools, operating on local files on disk. I also have to click "open" twice.
Old 03-27-2021, 10:18 AM
JFreak's Avatar
JFreak JFreak is offline
Guys please read the Help Us Help You document linked to the forum header
Janne
Old 03-27-2021, 10:28 AM
Same issue here.
MacbookPro i9 2019
macOS 10.14.6
Pro Tools Ultimate 2021.3
HD Native Thunderbolt
Omni
All optimizations done. Prefs trashed, etc.
Scott Gatteño
Old 03-27-2021, 10:33 AM
So you are sure that PT on Mojave is not broken? I am working with PT since version 4.x and I know the troubleshooting procedures. But I can't imagine that this has something to do with AAE prefs or something like that. Would be great to know if this is really not a simple bug on Mojave, then I don't have to start all this delete prefs and database stuff.
btw, I think the problem is the Import Audio dialog only.
OS 10.14.6, Mac Pro 5.1 (mid 2010), 24 GB
Radeon RX560
Old 03-27-2021, 11:10 AM
In the reademe Avid says that there are some changes in the dialog (shortcuts) for BS compatibility.
However, it would be interesting if there is someone on Mojave and could test the browsing issue. Maybe this is just a side effect of the changes that was not found in test.
Expanding folders seems to work (good workaround), only double clicking on a folder does not work anymore. And I have the "open twice" issue as well.
Old 03-27-2021, 12:46 PM
Actionmusic Actionmusic is online now
confirming original posters problem here
Mojave 10.14.6
Pro Tools Ultimate 2021.3. , native thunderbolt box
Mac mini 2018
accessing local disk
Can't navigate through folders on Import Audio window by clicking as before
Workarounds: drag folder or file from Finder onto Import Audio window to access, or if arrow to folder is visible in Import Audio window can open the folder there and select file.
yes an annoying bug to fix please!
Old 03-27-2021, 12:59 PM
weezul weezul is offline
Oh my god. Same here, on Mojave. Just checked! That's very annoying.
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 03-27-2021, 01:15 PM
And here I thought it was because I'm using an unsupported operating system - High Sierra.
Jack
QAPLA!
Import Audio crashes PT Ultimate 2021.x Metalgez Pro Tools 11 07-03-2021 12:42 AM
Double Clicking on Aux Track doesn't open Track Color window atothegreen Pro Tools 2018 17 03-28-2018 03:34 PM
Crash when double clicking to create new track while recording audio DJ Hellfire Pro Tools 12 4 04-20-2016 10:44 AM
Importing Audio by double clicking a clip defaults to Add relder17 Pro Tools 10 7 09-08-2013 09:29 AM
