Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 09-18-2020, 10:46 AM
uphillstudios uphillstudios is offline
Default Correcting Files that are playing at 2X Speed
I NEED HELP. I received files to mix at 96K/32 bit float. When I open a session with those specs, the files are playing at double speed. Even when I open the files in iTunes they are playing at warp speed. So they were certainly exported incorrectly. How do I force these files to be played back at normal speed?
Old 09-18-2020, 11:06 AM
Top Jimmy's Avatar
Default Re: Correcting Files that are playing at 2X Speed
If they’re exactly 2x speed and pitch, then the actual sample rate is 48 instead of 96. Create a new session at 48 and import the audio without sample rate converting, or when importing into a 96 session turn on sample rate conversion and manually change the source rate to 48.
James Cadwallader
Old 09-18-2020, 11:16 AM
Perfect solution
recordings playing back at twice the speed Tommy Heanue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-16-2009 01:11 PM
playing different regions at half speed? thechakras 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2006 02:45 AM
PLAYING A WAV FILE AT HALF SPEED digimike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-10-2006 12:04 PM
Help PT is playing back at 1/2 to 1/4 speed qbert1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2003 07:42 PM
24bit files for mastering & non error correcting media thankyou! [Benjamin] Pro Tools TDM Systems (Mac) 0 02-27-2000 03:40 PM
