Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 09-14-2019, 08:16 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Using Multiple-Mono Plugins
There's so many ways to do stuff in the digital mixing realm, its hard to keep it all straight. I came across a video showing how to use multiple-mono plugins in PT on stereo tracks to apply different EQ to left/right channels, and even mid-side. Just for fun I tried it out on a stereo VI track that had definite left/right bouncing and differences, and it can change the sound dramatically. So, it got me wondering, how often do you guys go for using multiple-mono plugins, and how do you employ it when you use it? Is it something you do on almost every mix, or only once in a while? Just curious how you pros use this technique? Thanks
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 09-14-2019, 12:05 PM
EGS's Avatar
EGS EGS is offline
Default Re: Using Multiple-Mono Plugins
If I need to process one side differently than the other (rarely), I just copy it over to 2 mono tracks and tweak each separately as needed. Easier/faster. My 2 cents!!!
Click for audio/video demo
Click for resume
Old 09-14-2019, 01:06 PM
amagras amagras is offline
I use most of my parallel chains in multi mono, that way they preserve the stereo image of the tracks sent to them (as long as you keep the pan in the send linked to the track). For reverbs and delays you can use the pan pot on the send to separate the effect from the original signal, for example pan the track to the left and the send to the right but if I want my reverbs to expand the space around the track, for example on lead tracks, I use stereo. My template has both versions inactive on all the auxiliaries, then I just activate stereo o dual mono as I need.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 09-16-2019, 08:43 AM
DonaldM's Avatar
Thanks for the insights on this. I can see some potential ways to use this, but I don't see using it on a regular basis for the type of thing I do.
Old 09-17-2019, 01:48 PM
It grows on you, just knowing it's there and how it works will save your bacon when dealing with busy mixes and large track counts
amagrasmusic.com
For mastering - multiple mono or interleaved? kirkbross Avid Pro Mixing General Discussion 12 01-18-2020 06:44 AM
Glitch when bouncing multiple mono tracks? LAlexander Pro Tools 2018 6 08-14-2019 03:40 PM
9.0.2 changed all my sessions to bounce multiple mono? crizdee Pro Tools TDM Systems (Mac) 2 03-16-2011 03:58 PM
Converting multiple mono to stereo interleaved danielpetry Tips & Tricks 1 01-05-2007 08:58 PM
New EQ3 : why as multiple Mono only ??? gorka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-22-2005 08:06 PM
