Old 12-15-2018, 08:53 AM
colliderman colliderman is offline
Default When using Artist mix in Studio One under mackie control..
Is it possible to change what's being displayed on the OLED?
The fader and pan functions are working well in Studio One, but there's some quirks about what's being displayed on the channel oled.
For example, track names are displayed twice, once in the track name section and again above the pan position. Touching the pan rotary knob changes the pan display to show the track volume level. Touching the fader makes the track name disappear.
Obviously this is not ideal as you can't see the track volume as you're moving the fader. The only way to display track volume is by touching the pan pot.
Is this an issue with the way Studio One implements mackie control or Avid and is there any way to change what's displayed?
Pro Tools 2018.12
OS X 10.14.6
Mac Mini (2012) Quad 2.3 GHz Intel Core i7
16 GB 1600 MHz DDR3 RAM
Old 02-21-2019, 08:15 AM
Default Re: When using Artist mix in Studio One under mackie control..
For anyone reading this having the same problem, I manged to fix it by adding some code to the MCU script in Studio One. I can share it if anyone's interested.
Would've been nice if Avid actually properly implemented Mackie Control protocol as advertised. Metering of tracks, proper display of track names and values could and should all work as expected.
Pro Tools 2018.12
OS X 10.14.6
Old 02-22-2019, 07:48 AM
EddieJones's Avatar
I think this is a Studio One issue not ours...other Makie Contral App don't do this.
[Help needed] Using an Artist Mix & Mackie Control for FOH setup with a Fireface 802 AntoninL Artist Series 2 01-22-2018 09:03 AM
Getting Artist Mix and Control to work with Studio One v3 michaelhulse Artist Series 2 07-23-2017 04:48 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
Darn, the studio I work for bought an artist control combo :( zblip2 Artist Series 4 02-24-2012 08:23 PM
Darn, the studio I work for bought an artist control combo :( zblip2 Artist Series 0 02-20-2012 06:14 PM
