Old 09-30-2018, 06:38 AM
Tigerspill Tigerspill is offline
Default Brand /Console independent digital snake
Not sure if this is a good place to post this as it isn't Avid specific.
Can anyone recommend or suggest a digital snake product that is console independent. Most seem to have a stage box, and expect a specific console to be at the other end.
I am looking for something with a set of AD connectors at the stage end and a set of DAs at the other end where I can plug in any console. Plus a few DA/ADs for returns.
Also what is the best digital connection to use - RJ45-Cat5/6 or something else for audio dedicated?
Thanks
Old 10-01-2018, 07:07 PM
Default Re: Brand /Console independent digital snake
Dante is probably the best solution for this. But, having said that, what is your reasoning behind this need? Using hardware that was designed as a system would usually be more dependable(which is crucial in live audio)
Old 10-02-2018, 10:38 AM
RyanJ's Avatar
RyanJ RyanJ is offline
These days you've got 3 typical connections. RJ45/"Ethernet", BNC/MADI, and Optical/various formats.
If your goal is to run a snake in a venue that can connect to anything on either end, you'd be best suited to do something like running all three of these.
2x CAT5e, or CAT6 will cover: Avid S6L desks, DiGiCo SD9, Yamaha CL or PM series, Midas Pro series, and I believe DLive series
4+ BNC will cover Avid Profile and D-Show, DiGiCo SD series, SSL Live series
2x Multi-Mode fiber to Opticon will cover DiGiCo SD series also, can be used with Avid S6L, and can be used with SSL Live (with Blacklight conversion), the complexity with Fiber is that there are so many connector formats
I'm sure there's much more nuance to this, but that's a quick overview of my thoughts on what I would want to pre install if that's what you're asking... But also, as a touring engineer, I'll almost always choose to use my own snake over the house snake, because I trust my own, and don't always trust theirs...
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
Old 10-05-2018, 04:21 PM
SteveGam SteveGam is offline
I have a roland S4000 snake system for sale if that is what you are looking for.
Working for the preservation of quality live sound.... One show at a time!
Work
Twin S6L's
PM-10
Profile, D-Show
3 Midas Heritage's and 5 M32's
Several other analog and digital consoles
d&b J Systems
L'Acoustics V-Dosc systems
Home: Compaq Z800
Dual XEON hexes
48G Ram
Windows 10
Midas M32 and XL48
Genelec 8050's with Genny sub
Genelec 8030's
JBL L96 & LSR32
Digi 002 Mixing Console to brand new imac SgtB903 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-29-2013 06:55 AM
multiconnector for bnc digital snake? Rockpolice VENUE Live Sound Systems 4 02-27-2012 09:09 AM
Brand new R11 Digital NOISE !!!! Paul B. Eleven Rack 11 02-04-2011 08:20 PM
Digital Snake length limit chtam VENUE Live Sound Systems 2 01-02-2008 07:43 PM
need the wiring scheme for the 192 AES Dsub to XLR digital snake spong Pro Tools TDM Systems (Mac) 2 03-24-2002 06:10 AM
