Old 05-17-2018, 12:17 AM
ric982 ric982 is offline
Default Windows 10 Version 1803 Update - Hang in Protools
Windows 10 Version 1803 was installed on my computer on 5/14.
When I start protools now, it
- logs into avid account,
- loads plug-ins (waves)
- Flashes through several windows including one that says something like "Configuring Yamaha Steinberg driver,..."
- Hangs with the banner saying "Loading Plus-Ins: XPand!2"
and a small window with "Windows Installer / Preparing to install ..."
This seems to hang forever.
There is a cancel button. If I press it it says "Windows Installer/Canceling..."
and this seems to hang forever.
I can kill protools with the task manager and it goes away.
If I restart, same problem.
BTW - I can use Itunes to play music through my UR824 and if I check the driver in the control panel, it says it's up to date.
Any thoughts - others with same problem?
Old 05-17-2018, 06:24 AM
YYR123's Avatar
YYR123 YYR123 is offline
The best know practice is for you to not use your interface for your Windows Sound...don’t know if that’s causing a problem...
Can you manually download the xpand update?
Do you really even need the expand update?
You can always trash prefs and restart
Daniel
Old 05-17-2018, 07:05 AM
DeadAgain DeadAgain is offline
Default Re: Windows 10 Version 1803 Update - Hang in Protools
Hi Ric,
I had the same problem with my UR interface after installing 1803 ... hanging at the same point.
Everytime I tried to start Pro Tools, the startup triggered a windows installer for my audio card driver in the background that never finished and blocked the startup.
1. reboot your PC (just for cleaning up)
2. remove your audio driver for UR
3. reinstall the driver
4. boot up protools
That helped me.
Greetings
Alex
Old 05-17-2018, 06:04 PM
leftalive leftalive is offline
This won't be of much use to OP, but fwiw to anyone else who happens upon this thread, it might be a good idea to hold off on 1803 for as long as possible. I have a friend here in town that builds systems for audio, and he's run into a few hiccups of his own.
There's also a (generally) great thread on Win10 over at GS, where one of the audio guys from Microsoft regularly chimes in, and there seem to be several reports of flaky behavior with 1803 over there as well. Be warned though - right now the thread is mostly 3 or 4 knuckleheads yelling at each other over forced updates.
PC workstation:
Windows 10 Pro
i7 12700K
RTX 2080ti
64GB DDR5 5200mhz RAM
2 Samsung 980 Pro 1TB SSDs
Samsung 850 Pro 1TB SSD
LG 34" Ultra-Widescreen monitor
Pro Tools 12.4
A loaf of bread
A stick of butter
A lot of rye whiskey
Old 05-18-2018, 08:32 AM
Its easy to just roll back to the previous build if you want to. I may be off here, but the backup of the previous "setup" stays on your system for about 2 weeks.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 05-18-2018, 09:39 AM
The Weed's Avatar
The Weed The Weed is offline
Or you do the right thing and image regularly - and get guitardom's utility to stop Windows updates
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-18-2018, 01:56 PM
Ok - so this is the OP.
1) First - Yamaha Steinberg is aware that Windows 10 1803 trashed their driver. I asked them if they were working with Microsoft to make sure that this does not happen on the 'next' update and he said they were. Not sure if that has any bearing on Version 1803.
2) I tried to uninstall the driver through Windows
Control Panel>Device Manager>Sound, video and game controllers>Steinberg UR824: Driver tab: Uninstall Device" and did not click the 'delete software' box. This is not the correct way to do this and led to (3).
(3) When I tried to use the Steinberg Tools for UR824 to reinstall driver software, it wouldn't let me select any software. So now driverless. After a somewhat long chat session with Steinberg USA, they gave me a support number to call and the person there was very helpful.
4) What we did was:
a) Windows Control Panel>Program and Features
Select Yamaha Steinberg USB Driver
Uninstall
b) Go to
https://www.steinberg.net/en/support/downloads.html
Click pull down on 'Downloads Hardware'
at bottom of list is:
- select and download that
- unzip and install
Now UR824 working OK.
Protools not hanging.
Protools 10 With Windows 8 (Full Version) auratone Pro Tools 10 11 12-09-2012 05:15 PM
Protools 10.2 update is out now for Mac and Windows nst7 Eleven Rack 2 05-21-2012 08:32 PM
Best version of protools to use with digi001 on windows tfrazier1964 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-27-2009 09:06 AM
Update or upgrade the protools version mboxpro Pro Tools TDM Systems (Mac) 2 11-11-2008 02:07 PM
Updating to Windows XP version of Protools Saul Goodman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-12-2003 12:34 AM
