Old 04-16-2018, 04:00 AM
dsk1990 dsk1990 is offline
Default There was a problem stopping pro tools
Hi all
As you can see from the title I am having problems with my pro tools. I am currently a university lecturer teaching audio post-production/Foley work and I need my pro tools to prep lessons and grade work.
At the end of last year, I bought a new laptop as my old was near the point of death. My problem is my new laptop cannot handle videos what so ever even though it is an upgrade to previous.
Within Pro Tools 11.3.1 I input my video as normal a white small window appears (similar to the video window). Once I play a second window appears with the video yet the frames do not move, only audio is played. When I press stop it comes up with the error (there was a problem stopping pro tools).
This error stops me entering the top screen menu's (file, edit and so on). I have tried different codex's and stayed with DNxHD due to recommendations from other forum posts.
It is driving me up the wall I have no idea what to do! ... I know using a laptop is not the most ideal but it allows me to work on the go if need be. I have used Pro Tools to work with audio with little problems, it's just the video that is currently sucking.
Any help would be appreciated
Many Thanks
Processor AMD A9-9420 RADEON R5, 5 COMPUTE CORES 2C+3G, 3000 Mhz, 2 Core(s), 2 Logical Processor(s)
Installed Physical Memory (RAM) 4.00 GB
Old 04-16-2018, 05:09 AM
Default Re: There was a problem stopping pro tools
What version of Windows? PT11 isn't qualified beyond Win7.
One of your problems is that 4 gig of ram in your sig file which is way incomplete and doesn't make much sense. That is nowheres near enough ram to run PT11 with video. You want a minimum of 8gig and preferably more.
Have you optimized the computer for PT work? You need to do that to make as much use out of your setup until you put more ram in.
Jack
QAPLA!
Old 04-16-2018, 09:01 AM
The Weed's Avatar
The Weed The Weed is offline
And only 2 cores? Way underpowered besides not enough RAM.
See the "Help Us Help You" link, do all the optimizations and post a Sandra Report.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
CPU Spiking and Stopping Pro Tools Glo123 Pro Tools 12 4 09-13-2017 07:29 AM
Bug: "There was a problem stopping Pro Tools" Meads Pro Tools 11 57 05-29-2016 06:40 AM
Pro Tools 11 HD Lag when recording and stopping asaffulks Pro Tools 11 8 08-07-2015 10:24 PM
Starting and Stopping Pro Tools from Venue Scott Fahy VENUE Live Sound Systems 4 02-14-2012 12:43 PM
DIGIDESIGN-Pro tools stopping at 33 minutes sean shannon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 28 04-07-2003 05:25 AM
