Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 07-03-2017, 07:11 PM
NAEP_Matt NAEP_Matt is offline
Default S5MC Power Supply Alarm?
Hi, I just returned from a couple days away, where I had my whole 32 fader S5MC system shut down at the power strip (that is, in front of the S5MC's power supply. When I powered it up, I heard a faint noise coming from the the unit that I've traced back to the MC's power supply. The noise stops when the MC is shut down, or when its restarting, and only fully comes back once the whole system is back up and running. Otherwise, operation seems to be normal.
I'm wondering if it's some kind of an alarm, maybe a fan alarm? Anyone else experienced this?
Thanks!
Matt
Old 07-04-2017, 11:41 PM
niekbeem niekbeem is offline
Default Re: S5MC Power Supply Alarm?
There is a small (but quite noisy) fan inside the MC Pro's PSU, but I don't know about the CM408T's PSU's.
Maybe it just got dirty while it was not being used?! Try cleaning it first?!
Niek/ Amsterdam.
Pro Tools Ultimate 2023.6 / Nuendo 12 / Logic X / WaveLab 11
MacPro 5.1: 12Core 3.46GHz Intel Xeon/ 48GB RAM/ Mac OSX 10.14
MacBook Pro: 2.9 GHz Intel Core i9/ 32 GB RAM/ Mac OSX 10.14
MetricHalo ULN8 + 2882 / RME HDSPe MadiFace
Euphonix MC Pro
Old 07-05-2017, 09:39 AM
EddieJones's Avatar
Modifying MC power supply to resolve MC Checkerboard TFT.pdf
The only thing we can suggest is to check the voltage using this doc. Be careful.
Old 07-05-2017, 11:29 AM
Thanks for this, Eddie.
This morning, after letting the system run all night, the sound has stopped. So I'm not sure what I'm dealing with, but I'll continue to monitor & post back if there's anything useful to share with the DUC.
Cheers,
Matt
Old 07-25-2017, 01:50 PM
It's baa-aack. And annoying as hell. It's not the fan. I tried adjusting the voltage, doesn't help. Given that these things are $650 a pop, and this one is less than two years old, any chance it's under warranty?
Can't post video here, but I'll post it on the Eucon group on FB.
Old 07-25-2017, 02:34 PM
EddieJones's Avatar
Sounds like one of the transformers, Without electrocuting yourself press sown on them to see.
Old 07-28-2017, 03:02 PM
ErikGuldager ErikGuldager is offline
Well those are not the best engineered PSUs ever...
I have two MCs original silver version and I think we have had like ten or so replaced over the years.
That tiny inefficient fan is likely a part of the issue is my personal guess.
I have had some units totally short and burn out parts inside of them. Fortunately I don't think I have lost a SBC because of that though.
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
Power supply?? aboynamedchris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-21-2008 01:52 AM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! snuffacation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-11-2004 03:03 PM
